hey guys, suspension problem??? help please!
Old Jun 24, 2008 | 08:36 PM
hatrick6's Avatar
so i have a 1995 240sx se, i just replaced the tension rods on both sides because the old ones were visibly worn out. after the new ones were in and i took her for a test drive there seems to be some kind of weird "thud" noise whenever i hit the brakes going forward, it doesn't do it in reverse. the noise seems to be coming from the front driver side wheel area (although it could be on passenger side also, not totally sure). the thud only happens when i first apply the brakes, its not a continuous noise, and it does happen EVERY time i first apply the brakes, i.e. if i hit the brakes on and off the noise repeats itself every time i touch the brakes.
so, any ideas???? i have a race this weekend and im hoping to have her ready for that.
Old Jun 24, 2008 | 10:21 PM
did you make sure everything was tightened properly?
Old Jun 25, 2008 | 04:16 AM
hatrick6's Avatar
ya, i tightened everything, there are only 3 bolts on each tension rod, 1 in the head and 2 in the tail, and i made sure that all 3 in each rod were tightened well.
Old Jun 25, 2008 | 04:56 AM
yea make sure that the bottom two are tight dude bro... i had a nut come off on mine while drifting.. and yes you will get a forward motion after braking. also make sure the forward section of the tension rod rack is tight
Old Jun 26, 2008 | 04:23 AM
hatrick6's Avatar
well, as surprised as i am to say it, ya the bolts needed to be tightened. they were pretty tight to begin with, and i didn't want to over tighten them or strip any nuts, but after reading the replies from you everyone here, i went back and torque'd the hell out of them, tightened as hard as i could, and that fixed the problem. huh, sounds weird to me for the sounds i was hearing, but it worked!
Old Jun 26, 2008 | 05:14 AM
glad to help
thabeast
Aug 10, 2006 06:42 PM
thabeast
Aug 8, 2006 01:35 AM
kanda
Jul 2, 2004 09:48 PM
swannjay
Apr 10, 2004 10:31 AM
japporeyser
Apr 7, 2004 08:15 PM
