Hicas
Old Jul 30, 2003 | 09:12 PM
TruDirtyPlaya's Avatar
Hicas
Does you car need to come with HICAS? or can you install it? or do you really need it... and I have 90, so how do you tell
Old Jul 30, 2003 | 09:28 PM
Jonas's Avatar
from what i know only 91-93 SE model s13's came with hicas...another way to know if look for a rack & pinion out back, or look on the console for a HICAS warning light should be on the right hand side of the steering wheel...BTW Why do you want HICAS!!!??? its crap its weight, its stupid if your doing an sr swap like myself, iam using my power steering pump to pump fluid out the the hicas instead of my power steering...just be glad you dont have it, the up part of having my car hicas equiped is that it came with LSD yay!!
Old Jul 31, 2003 | 01:57 AM
m2hui's Avatar
i'ma cook at this restaurant called whitespot.. 8.50$ cdn/h
r most ppl from here from the states?
Old Aug 2, 2003 | 01:08 PM
rudeboy's Avatar
wow.
thanks for the info
Old Aug 2, 2003 | 02:10 PM
m2hui's Avatar
wtf? i dunno how my post got into this thread...
um.. yah
Old Aug 3, 2003 | 12:50 AM
S30's Avatar
S30
Wow, that hurt my feelings, I have Hicus
Yeah it's a pain when you have to do a SR cause you'll have to find a sr w/ hicus or change out your subframe. Well I'm not 100% sure on the subframe but it's a pain. You can tell if you have Hicus either w/ the light next the the rear wipers buttons or like what Joanas said.
But I have LSD hehe.
Old Aug 3, 2003 | 01:48 AM
rudeboy's Avatar
why do you need a special sr cuz you have hicas???
you dont....
period
so keep lookin and peepin prices, then boost up
Old Aug 5, 2003 | 07:26 AM
spitz7985's Avatar
you don't need a special SR when you have a HICAS equipped 240. you can either buy a SR and not hook up the HICAS or you can buy an SR HICAS PS pump from heavythrottle.com. they usually have some available. you do not have to change out the subframe.
there is no rack and pinion out back. the HICAS used on our cars has a piston that pushes the tie rod on each side. the rear wheels only turn 1 degree. there was a later generation of HICAS that did use a rear rack and pinion. it was only available on skyline GTRs.
Old Aug 5, 2003 | 09:47 AM
S30's Avatar
S30
Cool!!! Now I can yell at someone for giving me funny info. Thanks guys.
Old Aug 7, 2003 | 01:54 PM
Jonas's Avatar
dude 1 degree?? ive heard it turning atleast 3 degrees?? another questions... if iam not sending any ps fluid out to the hicas whats going to happen?? because right now i have the ps going out to the hicas because i was worried they might turn on their own while iam driving a straight line or so...so iam sacrificing my p.s as it is going to the hicas, problem soon to be solved though once i get this hicas pump in..
slipperypanda
Jun 25, 2007 05:44 PM
Jonas
Jun 16, 2004 09:54 AM
Import Fanatix
Jan 23, 2003 12:53 PM
89240sxmup
Nov 7, 2002 06:19 PM
spitz7985
Jul 29, 2002 02:24 PM
