Lucas fuel injection cleaner and code 45??
Old Dec 10, 2007 | 07:15 PM
Originally Posted by scooz14
my aiv is dumping a ton of **** on my brand new air filter. what is the issue with this, is it safe to remove with no terrible side effects??
you can take the aiv apart and clean it out or remove. if you remove it you'll need to block off the vacuum lines to it, the hole on the down pipe, and disconnect the solenoid.
Old Dec 10, 2007 | 07:29 PM
That means the valve is bad and is doing nothing, iirc. Try cleaning the valve.
Old Dec 10, 2007 | 07:50 PM
scooz14's Avatar
is there any side effects to removing the aiv??? mainly the cel?? idle quality??
Old Dec 10, 2007 | 10:32 PM
Nope. I dont even think it will throw a CEL if you just cap it off at the valve, not sure though. A lot of people take it off because it fails and doesnt really do much for emissions.
Old Dec 11, 2007 | 01:31 PM
scooz14's Avatar
i've go the whole aiv system out, i decided to weld the hole shut with a nickel. what do i do with the solenoid, and the vacuum hoses that run to it. can i just trace those lines back to thier origin and hook them together??
S14_Turbo
Jul 18, 2007 09:42 PM
gotspeed
Sep 16, 2005 04:18 PM
nonbox
May 15, 2005 05:47 PM
swannjay
Aug 25, 2004 04:02 PM
thegary
Feb 22, 2004 05:30 PM
