My car is running like crap...help!!
Old Aug 28, 2007 | 07:56 PM
fanmanflex's Avatar
I need some help, I have a 93 with like 192K miles and fairly recently its just been running like crap.
it idles really low, like down to 300 and often dies, it often dies when i take a quick corner and brake a little harder or something, sometimes it will just die every time I brake.
Ever since i've owned it, i've ran 91 octane, i just replaced the fuel filter to no avail, and replaced the O2 sensor also doing nothing, anyone have any ideas?
Old Aug 28, 2007 | 08:00 PM
i have many ideas.
one of which involves cleaning or replacing your iacv.
Old Aug 29, 2007 | 01:14 PM
fanmanflex's Avatar
IACV? sorry i probably know what it is just not in an acronym.
Old Aug 29, 2007 | 03:27 PM
LA_phantom_240's Avatar
Idle Air Control Valve.
Pull off the larger hose on your intake piping, near the radiator hoses.
Use seafoam or spray this stuff meant for mass airflow sensors (not carb cleaner!!!) into it.
Old Aug 29, 2007 | 04:45 PM
that will help if it is dirty. if that doesn't help you'll need to remove it and check the resistance. if it's good it will read about 10 ohms.
Old Aug 29, 2007 | 06:19 PM
Chuki_User's Avatar
Mine was doing the same thing and it ended up being the M.A.F (mass air flow) connector.
Old Aug 29, 2007 | 09:42 PM
a bad or dirty maf can cause these problems too. so will a(or all) dirty injector, weak fuel pump, poor ground, weak battery, bad alternator, faulty ignition system......the list is long but i always recommend the cheap and easy
fixes first.
Old Aug 29, 2007 | 09:52 PM
Or run the codes, see if it throws anything back at you.
Old Aug 30, 2007 | 12:05 PM
I gotta do that soon
Old Aug 30, 2007 | 12:32 PM
for some reason my 240 never gave any codes.
Old Aug 30, 2007 | 07:41 PM
was there anything wrong with it? lol
nighthawklude99
SR
Jun 11, 2007 07:49 PM
krzykrackr
Jul 10, 2006 03:18 PM
s13 drifta
Jun 27, 2006 10:58 PM
motegineon
May 9, 2006 02:44 PM
Sackajaweeba
Aug 13, 2004 08:29 AM
