Car runs like crap!!!
Old Apr 6, 2006 | 12:53 PM
Angry Car runs like crap!!!
Ok so i get 550 inj, z32 maf, and safc. Start the car with a 2 in and 6 out, its runs great...then i go and get it tuned and get back home, start the car and it rruns like ****! (i did get dissapointing results which i believe reflect a problem) i notice the bov is blowing air at idle, so i fix this. Im assuming this is what causing my crappy idle and performance. Well i fixed it today and the car still idles and runs like crap. I dont know if the tune is just that ****ty or what but something is wrong. Also i dont know if this attributes to anything, But i noticed for the first time, oil came out of that little nipple on the bottom of the throttle body ( i believe its for the stock sidemount). And my vaccuum is lower than usual but all hoses are connected. So please people enlighten me!
Old Apr 6, 2006 | 04:37 PM
All Mighty KA-T's Avatar
Bad MAF maybe? ( Mine did that ) Idled like S**T untill i replaced my MAF, or make sure your O rings on your Injectors are not leeking.........what do you have the SAFC set to ( On Low/High )??
Old Apr 6, 2006 | 06:18 PM
chiroke's Avatar
so ppl say 550's are 2 big for safc maybe they r right and some ppl say 550 is fine with safc maybe they are wrrong. but fuel is ur problem
Old Apr 6, 2006 | 08:02 PM
Yea but can the maf just go bad like that, i mean it idled and everything fine before the tune....and also vaccuum is like 15 instead of the normal 20, im gona make a vaccuum test tomorrow.
Ok heres the numbers, 2in and 6 out for the maf.
Hi: 1000(-12) 2000(-13) 3000(-17) 4000(-24) 5000(-28) 6000(-30) 7000(-28) 8000(-30)
Low: 1000(-16) 2000(-20) 3000(-17) 4000(-17) 5000(-18) 6000(-18) 7000(-19) 8000(-17)
Low 10% and high 50%
Please tell me what your numbers are and what yall think about this?!?! Thanks a lot.
Old Apr 7, 2006 | 09:08 PM
hicksx's Avatar
have you found anything out? did you get it fixed?
Old Apr 7, 2006 | 09:20 PM
nsn240's Avatar
550s are fine on an safc, they are not the problem... check your orings, maf, o2 sensor, water temp sensor etc
Old Apr 9, 2006 | 03:17 PM
ok so heres what i have done:
boost leak test - good
compression test - 140 all across
new spark plugs - good
tested coil packs - good
checked all vaccuum lines - good
no smoking at all
car still runs like crap and is extremely slow...sounds like a bad misfire or like its running on 3 cylinders..
Now i am completely stumped, anymore ideas people before i take it to a shop and get ripped off??
Old May 9, 2006 | 02:44 PM
just to let everyone know, i finally got my car fixed. Apparently an injector wasnt dialed in correctly which was causing cyl #2 to no receive any fuel. Thanks for the help.
yarou
Oct 6, 2012 08:25 PM
fanmanflex
Aug 30, 2007 07:41 PM
90 Sileightyguy
SR
17
Mar 28, 2007 08:23 PM
Acecool
Feb 5, 2007 06:08 AM
Rasago
Sep 14, 2005 05:59 AM
