radiater problem
radiater problem
hey, i just got one of those nismo radiater caps and as I was taking off the old cap coolant went everywhere. Right went i unscrewed the cap, it just sprayed everywhere. Ill probably need to put more back in but im not sure if I want to start my car. Is coolant flammable?
Flammable? No.
Was the motor still hot when you did this? If it was cold, it shouldn't have done more than bubbl a little, then settle down.
Probably a good thing you're replacing the cap. check to see if your overflow tank has coolant in it, if not, add some there with the cap off and make sure it runs out into the radiator. Fill the radiator to the bottom of the neck and put the cap back on.
Then fill the overflow tank right to the "cold" line. Keep an eye on it to see if it changes alot over the next few days...
l8r
Edit: Yeah, what s13 said!!
l8r
uvamosk
Aug 12, 2005 07:31 PM
