running rich
running rich
i got a question can running rich make you smoke from the exhaust at idle?
well when my engine is at operating temp i smoke a bit at idle. i thougt it was that my turbo was leaking oil but i check my oil level alot and it dosnt seem to be getting lower.
i know for a fact im running really rich so i was wondering if the unburnt gas in my exhaust is burning and making smoke.
what color is it? it could just be condensation if it is white. grey/black indicates it running rich. If you are on the stock sr ecu you could have problems with the fuel pressure or possibly the injectors. get a wideband on that sucker.
its like a grey im gona hook up a wideband this week but i know its running rich cause i smell it and when i step on it my friend sees it when hes behind me in another car
yes unburnt gas will cause your car to smoke.
the color can be deceptive. if it is bad enough you can smell the gas coming out of the exhaust. if it smells sweet it's coolant and oil will leave build up on the tail pipe.
