Tune-up?
Old Dec 27, 2003 | 12:48 PM
ryan15's Avatar
Tune-up?
I want to give my car a tune up, what are the part #`s for oxygen sensors, and spark plug and wires and anything else I might need.And post what kind of spark plugs you recomend.
Ryan
Old Dec 27, 2003 | 12:57 PM
http://www.club240.com/forums/showth...hlight=tune+up That post should help ya out a bit. Cant you just use a generic o2 sensor??
Old Dec 27, 2003 | 03:41 PM
drnovascotia's Avatar
Great link Hyjnx.
If you're going full tune-up, chiltons goes over eveything, well, most things.
Spark Plugs - NGK's are arguably the best
Fuel Filter - Upgrading to a 300zx fuel filter is supposed to be better, but either way a new fuel filter will help
seafoam is supposed to help, i've used it and it helped.
Plug Wires - Again NGK makes some good one's, but there are other's out there.
Air Filter
Fuel Injector Cleaner - many people forget this, I do it everytime I change my oil
Drain and refill your coolant from the radiator - helps your car from overheating
Check all your radiator and other hoses for cracks, bloating and leaking
Water pump - when was the last time it was done? Belts as well?( not the timing chain)
Drain and fill your tranny fluid - althogh nissan doesn't specify i'm told, many people do this every 30K.
Chiltons goes over most of those, but the FSM goes over them all
hope that helped.
Dr.
Old Dec 27, 2003 | 10:58 PM
ixcocoyxi's Avatar
seafoam doc? is that really seafoam? never herd..
Old Dec 28, 2003 | 04:19 PM
Here's a good thread on it, has like 90 some replies so far, all about seafoam. Pull up a coffee and read up.
Seafoam
Helped my car noticeably.
Dr.
Old Jan 25, 2004 | 03:21 PM
mwy23's Avatar
Originally posted by drnovascotia
Great link Hyjnx.
Air Filter
hope that helped.
Dr.
Chiltons? FSM? can you please explain what this is? and where does everyone get their NGK spark plugs and wires from? im going to do a full tune-up and need to gather all the parts.
Old Jan 25, 2004 | 03:24 PM
Chiltons is a company that do automotive books to help you out to figure out problems on your car. FSM=Factory service manual If you dont have one, you should get one. They are VERY helpful.
Old Jan 25, 2004 | 03:56 PM
mwy23's Avatar
i was wondering what the FSM is refered to over here on the nissan side of the world. on the honda side, HELMS manuals contain all the info. so where can i pick up a FSM?
Old Jan 25, 2004 | 04:52 PM
They are sometimes on eBay, you can go to your local nissan dealership for one...but pay up the ***.
thegary
Mar 4, 2004 12:35 AM
thegary
Sep 19, 2003 09:52 AM
EAGLE 5
Aug 14, 2003 07:39 PM
StanBo
Northeast
17
Sep 26, 2002 09:51 PM
Jonas
Sep 23, 2002 11:12 AM
