using soft fuel line under the car?
Old Oct 24, 2009 | 09:07 PM
alex_s817's Avatar
im relocating my fuel lines to sit under the driver's side of the car and im having zero luck with the flare tool and fittings that i bought. I am contemplating using soft line to connect the factory hard lines to the new hard lines that are on the drivers side. is this a bad idea? what type of line do you guys suggest?
i was thinking about just using some steel braided high pressure fuel hose? it will only be for about a foot also
Old Oct 24, 2009 | 10:51 PM
why not use hard or braided lines?
Old Oct 25, 2009 | 06:08 AM
alex_s817's Avatar
i bought all new hard lines, but im having a hard time getting the right fittings to work on the existing nissan hard line. the factory line is 5/16 for the fuel feed and return, and 3/8 for the tank vent. So i bought 3/8 line and fittings and the 3/8 nuts wont fit over the nissan line. doesnt make sense and is just aggravating. i was thinking about only using about 2 ft of soft line just to connect the existing nissan line to the new stuff. it would be from right where the lines first bend to run up to the front of the car, up above the driveshaft, and then they would connect to the new hard line. if i had the money i would just run some braided line all the way up but i cant afford that right now
Old Oct 25, 2009 | 09:13 AM
when i built a 65 mustang and droped an Edlebrock crate motor in it i used steel braided line to get the fuel from fuel cell to the carbs. but since it used carbs theres no return line it all goes in >.>.
but yea just get some braided lines they will work fine.
Old Oct 25, 2009 | 05:19 PM
any high pressure line should be fine.
Old Oct 25, 2009 | 09:17 PM
alex_s817's Avatar
thanks guys, i ended up getting the hard line i bought to work. i hate flaring lines though haha
uvamosk
Jul 14, 2005 08:47 PM
speedyfox
May 13, 2005 12:27 PM
mr_lee21
Mar 27, 2005 02:03 AM
haipho123
Jul 25, 2004 11:15 PM
ryan15
Dec 27, 2003 12:44 PM
