vlsd not working
Old Aug 23, 2007 | 08:41 AM
agustin lopez's Avatar
Question vlsd not working
hey guys i have a 1989 240sx and it has vlsd. until yesterday it was working fine but yesterday when i burned out it only spun one whell i drove it around to heat the liquid and then burned out about 4 more times and same. waht can be the problem??? can the vlsd break??
need help thanks
agust
Old Aug 23, 2007 | 08:48 AM
heating up the liquid is not what you wanna do.. that would cause the silcone to unlock on you
also what i gathered from my research a while back online
Here's some good reading if your bored. From the Miata guys, http://members.aol.com/solomiata/MiataVLSD.html
A VLSD is made up of thin perforated plates that are suspended in a silicone fluid. The plates shear the fluid as the wheels rotate at different speeds. This shearing can equalize the different wheel rates thus limiting slippage. The VLSD only provides a 15-20% locking function when new, so they are not really meant to be a performance item. I have found that the locking action of the VLSD takes a moment to activate when one wheel starts to slip so it usually takes affect after you have already exited the corner. They are really meant to help you get the car moving from a dead stop in slippery conditions and not a performance aid. The VLSD works just fine for it's intended street usage but it will effectively stop limiting slip, from a performance point of view, at some point as the plates can break, the silicone fluid can leak and the tolerance between the plates can wear.
EDog
Aug 11, 2005 06:48 AM
silvia180SX
Aug 11, 2003 10:09 AM
wrxwgn03
Jul 27, 2003 05:19 PM
SilvaPwr
Jun 25, 2003 10:35 AM
rps13
Apr 10, 2003 12:48 AM
