what do you think
Old Aug 14, 2002 | 09:34 PM
leiferik1's Avatar
what do you think
when i reverse and when i am in first gear my car makes a noise like a chain is dragging on the ground...i'm sorry i can't be more specific, i don't really know all too much about cars
Old Aug 15, 2002 | 10:59 PM
Statik's Avatar
Is it like a scrapping noise, or a rattling noise. also does it sound metallic like two pieces of metal hitting. Is the car a stick or automatic if stick does it go away when you step on the clutch get worse or no change at all.
Statik of Speed Thrill
Old Aug 18, 2002 | 11:31 AM
leiferik1's Avatar
yes, its a scrapping noise that sounds metalilc
car is an auto and generally the sound goes away after i pass 10 mph
Old Aug 18, 2002 | 08:29 PM
Statik's Avatar
When the last time you changed the fluid, Or even checked it. Make sure the fluid isnt low anf if its not have the tranny fluid changed. If you have a shop do it, tell them to save your old fluid and watch them do it, Tranny shops are known to give you back someones tore up *** fluid and say you need a rebuild. There should be a couple small pieces of metal meaning normal wear, but if theres alot of small pieces or large shavings you have a problem. Also isnt your car new and under warranty.
Old Aug 18, 2002 | 09:02 PM
leiferik1's Avatar
my car is a 00...i think its still under warrenty
i've had all my fluids checked...i guess i'll have them looked at gain
Old Aug 18, 2002 | 09:03 PM
Statik's Avatar
Nah, If its under warranty take it back to the dealer. You dont want the Big O Tires flunky to screw up and the dealer wont replace the tranny (if need be).
jramosthe1st!
Apr 5, 2007 05:01 AM
adavib
Mar 8, 2003 04:50 AM
dennis
Feb 10, 2003 12:06 PM
leiferik1
Dec 1, 2002 03:27 AM
GERALDO RIVERA
Mar 5, 2002 01:10 PM
