How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
electric fan install
Old Nov 29, 2007 | 07:03 PM
i say go for it.
sticked or not it doesn't matter to me i just put this together to help out others with the proses.
Old Dec 1, 2007 | 01:29 AM
very nice, useful info.
i need to do this like asap.
Old Dec 1, 2007 | 01:00 PM
bucket240's Avatar
I just got done doing mines with duel altima fans and a F.A.L thermo switch. All you need is the instructions from the thermo switch to do the install (super easy). Only hard part was cutting all the plastic around the fans.
Old Apr 20, 2008 | 02:44 PM
shrimpscampi's Avatar
Thanks for posting...
Old Apr 20, 2008 | 06:58 PM
its good your trying to become involved w/ the forum and whatnot, but next time check the date of the thread.
Old Apr 20, 2008 | 09:32 PM
its good your trying to become involved w/ the forum and whatnot, but next time us the pm.
j/k carry on.
Old Jan 23, 2009 | 11:17 AM
jim shu's Avatar
very cool (no pun intended) mod/write up. It's hard to tell from the pic, but are the fans in front of radiator? are they pushing or pulling?
Thanks for the link
Old Jan 23, 2009 | 12:11 PM
yes the fans are in front of the radiator they are push fans. there are quite a few reasons for using these fans. the main reason is that i already had them and didn't want to buy others. the a/c condenser was removed to allow the fans to be more efficient and allow the oncoming air flow to help cool the radiator also. by placing the fan in front of the radiator i used the fans as a guard against debris also.
Old Jan 23, 2009 | 12:14 PM
jim shu's Avatar
what's this box against the radiator fins with the wires going to it?
Old Jan 23, 2009 | 05:12 PM
94 sentra_xe's Avatar
could you do a write up on this
no offence to this DIY but its kind of a messy install and the fans dont look that great, im sure everything works but im looking to do it on my s14 and everything needs to be done right and look OEM
Old Jan 23, 2009 | 05:28 PM
  #26
that's the adjustable temp switch. the temp probe is on the other side of the radiator under the upper radiator hose.
most likely that's not going to happen seeing as how he hasn't posted on here for some time now.
none taken, it is a bit messy because at the time i was rather pressed for time and was doing the write up because i was asked to by a few new members. now most of the wires and hoses are hidden quite nicely. as to the look well that's a matter of opinion. although you can't get much more oem than the original factory a/c condenser fans.
Old Jan 23, 2009 | 06:03 PM
  #27
allright thanks man, also thanks again for not taking it the wrong way....most message boards would have had ten more pages of people *****ing about what i said haha
Old Jan 23, 2009 | 10:12 PM
  #28
fadedsilvia's Avatar
in an s14 doesnt the a/c fan run with engine temp as well?
if thats the case then couldnt you just use that to run the altima fans?
that would eliminate having to get fan controllers or temp sensors, an alot of wiring.
an if your like me you can make your own "y" harness complete with plugs to jus plug in both fans to that one plug
or would this idea fail horribly an i blow up my engine from overheating on a mildly warm day?..
BigVinnie
Aug 7, 2005 12:27 PM
BMadd
Mar 4, 2004 07:43 AM
4984 5fsdskfvjdsntr4
Oct 23, 2003 04:10 PM
Doba's240
Oct 20, 2003 09:22 PM
Driftin180SX
Feb 25, 2003 01:51 PM
