How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
intake
Old Aug 18, 2007 | 05:40 PM
s13 short ram intake
at the request of some here i've put together this write up.
there are a number of ways to go about this but this was the most appropriate for me.
1.intake piping and filter
the piping was bought of of ebay. it is for a "92 240sx. the reason i bought this piping is because it has the same size fittings for the vacuum lines and the correct bends. you'll need to cut the pipe but first cut it a bite longer than needed and test fit it. don't get rid of the left over pipe because it can be added latter as a cai extension.
2. relocate battery.
this is simple enough to do and because there is already a write up on the matter i'll say no more about it.
3.maf & iat sensor plugs.
you'll notice that the wire for the are two sensors comes from the left side of the engine bay but they are tapped along with other wires.
remove the tape and re tape the wires so they can reach the new location of the maf and iat sensors.
4.aiv
if you plan on doing away with the air injection valve skip this part. if not you'll need a 1/2" tee that can be bough at any hardware store for about $.50 it will be placed on the large fitting on the intake pipe and leave a place for the crank case and for the air injection valve.
5. finishing touches
just tighten everything correctly and plug everything in and you're goof to go.
as always if something is unclear let me know so i can do my best to simplify the proses.
Old Aug 19, 2007 | 12:52 AM
good stuff... great pics bro
Old Aug 19, 2007 | 08:46 AM
thanks. the engine bay is a little dirtier than usual but i didn't have time to clean it.
Old Aug 20, 2007 | 03:27 PM
Brad240sx's Avatar
Thanks man! I did mine just the othe day lol works like a charm...but I put my battery in the trunk
aznchico69
May 10, 2005 02:17 PM
sr20240
Sep 11, 2002 12:53 PM
Sizzzoooo
Feb 26, 2002 07:44 PM
Chas
Feb 9, 2002 01:09 PM
