Alt. Pulley Removal
Old Feb 28, 2005 | 04:35 AM
CowboyTurbo's Avatar
Alt. Pulley Removal
Umm... having some trouble with this, but what's the best way to remove the alternator pulley on the Ka?
Old Feb 28, 2005 | 06:39 AM
Project Cheap13's Avatar
Take it to Autozone & they can remove it( take off the nut & the pully should come right off). Or if you have any air tools you can do it in the garage. All you need to do is hold onto the pully & the bolt will come right off. It's only about 60 ft lbs, if that.
You cant really do it with hand tools.
Old Mar 1, 2005 | 06:22 AM
awww crap... hmm thanks for the info. Don't suppose anybody knows how long the car will run if I use a trickle charger to charge up the battery? The damn things been sitting dead on my driveway for a month at this point...
Old Mar 1, 2005 | 06:27 AM
Incidentally, any advice on installing the alternator belt? I was having some trouble getting the belt around the crank pulley and alt pulley. So of course my cave man instincts told me to try and budge the alt pulley with a metal object and a hammer... 'nuff said.
Old Mar 1, 2005 | 10:33 AM
I've decided to just remove the alternator altogether and bring it to somebody w/a gun. Would you guys recommend removing the alternator from the top or bottom?
Old Dec 31, 2005 | 12:32 PM
Initial Daniel's Avatar
Anyone know if there is a routing diagram for the alternator belt?
Old Dec 31, 2005 | 08:47 PM
yea, it's in the FSM...
Old Jan 1, 2006 | 03:00 AM
Levi SPL S14's Avatar
why did you not adjust the tension of the alternator??
its just a 14mm screw with a 12mm nut.
Old Jan 1, 2006 | 12:42 PM
nsn240's Avatar
the alternator has the tensioner built in... looser that, drop the alt and install the belt... then pull it tight, bolt down. Trickle chargers, i usually leave mine on overnight and thats plenty
positron
SR
Jan 6, 2008 06:45 PM
bs280
Nov 6, 2006 09:30 AM
Indolent
Sep 6, 2006 09:17 AM
Purple240
Aug 1, 2006 06:46 AM
needa240
Apr 3, 2005 01:12 PM
