Car missing at low rpms need help please
Old Jun 25, 2007 | 09:20 PM
Alexl08's Avatar
I have a 92 240sx with a ka24de and I just put a new maf sensor on it and a cold air intake and now it seams to be fouling out the plugs at low rpms with to much fuel I have just stright gas coming out the pipe the car runs but not good at all what do i do how do i fix this please help
Old Jun 25, 2007 | 09:22 PM
Was it a brand new MAFS or a used MAFS. Sounds like it's bad to me. The cold air intake shouldn't have made that much of a difference. Did the old MAFS go bad? Why did you replace it in the first place?
You didn't use a Maxima or a 300ZX MAFS did you? The car has to be re-tuned for that.
Old Jun 25, 2007 | 09:27 PM
Alexl08's Avatar
I broke the connector off and i got a used maf off of my buddies car that blew up but it ran fine befor that
Old Jun 25, 2007 | 09:29 PM
Alexl08's Avatar
if not the maf what else do you think because it runs fine at high rpms just not a low and it it cuts off at low rpms mostly thats why I think the plugs are fouling out
Old Jun 25, 2007 | 09:37 PM
Your problem actually does sound to me like it could be a faulty MAFS. The numbers match on both the old and new MAFS, correct? And the intake and MAFS were the only two things you changed?
Old Jun 25, 2007 | 09:42 PM
Alexl08's Avatar
yeah but when I thought it was missing I did plug wires and plugs
Old Jun 25, 2007 | 10:56 PM
a vacuum leak maybe?
Old Jun 26, 2007 | 08:37 AM
Good point Ramos, did you hook up all the lines properly to your new intake? And did you put the stock resonator box back on or plug the hole that leads to it? If not you're getting way more air then the car thinks its getting.
Old Jun 26, 2007 | 09:04 AM
Durdan's Avatar
and that would make it lean.. not rich
i would make sure that your spark plug cables are all in the correct order. also, make sure your MAFS numbers match to the old one. ALSO, make sure that nothing shorted out when your old plug broke off. you might have burnt the maf trace on your ecu and might need a new one now.
Old Jun 26, 2007 | 10:00 AM
BigVinnie's Avatar
Assuming that you are using a G60 MAF you are probably running rich with that cold air intake on.
G60= miss chokes on dick, this means it really does suck badly!!!
I've heard nothing but problems using cold air intakes with the G series MAFS.
Don't know if it is caused from the swirl that isn't taking place directly at the filter to MAF, or if it is the way the HOT WIRE is cooled with the additional piping. In any case most people I know don't like cold pipes with the G MAF.
Make sure the MAF you are using is the correct one 1991-1993 KA24de's used a G60 MAF.
1995-1997 used a G70 MAF.
If you are using any other MAF then you will need a retune or an SAFC.
Alexl08
Jun 15, 2008 11:30 AM
clubredsilvia
For Sale - Part Outs
23
Aug 14, 2007 01:01 PM
v8killa
Nov 16, 2006 06:49 PM
2fourdeeman
Jun 10, 2006 04:45 PM
jmack240
Apr 29, 2004 08:00 AM
