car missing at low rpms dumping to much fuel
Old Jun 25, 2007 | 08:23 PM
Alexl08's Avatar
I have a 92 240sx and I just put a new maf sensor on it and a cold air intake and now it seams to be fouling out the plugs at low rpms with to much fuel I have just stright gas coming out the pipe the car runs but not good at all what do i do how do i fix this please help
Old Jun 15, 2008 | 08:29 AM
BlackZenki82's Avatar
I had the same problem, not that a extremely rough idle, but just a miss here and there, my plugs aren't fouling tho.... some things i did to mine to smooth it out a bit was pulling the IACV out and rebuilding it, the sping in the piston was a little compressed, i changed both my O2 sensors ( pretty cheap from oxygensensors.com) and ran some seafoam through the brake booster.... that helped out alot, i'm still running a bit rich but it's hella better than what it was prior to all that..... try cleaning out your MAF sensor with some sensor cleaner, it may not NEED it but it's always nice to have clean induction parts! good luck and hope some of this helps
Old Jun 15, 2008 | 11:30 AM
you might have an injector or two stuck open dumping fuel into the cylinder()s at all times.
driftapimp
SR
May 26, 2010 06:08 PM
LA_phantom_240
Aug 14, 2007 08:25 AM
Alexl08
Jun 26, 2007 10:00 AM
2fourdeeman
Jun 10, 2006 04:45 PM
jmack240
Apr 29, 2004 08:00 AM
