complicated O2 sensor problem.
Old Jun 11, 2007 | 05:46 PM
knives123's Avatar
Ok, my engine light came on a while go and i decided to check it now since my inspection is coming up. I have a 95 240 se with an obdII and using the obd2 checker got front o2 sensor problem. Got that replaced, o2 problem is still coming up. I following the procedure on how to check the if there is any grounding issues using the fsm procedure, and found out that i have wiring problem. So after all the jebbar jabber, has anyone ever had this problem or know how to deal with it? Unplugging the ECU and the oxygen sensor wire, checking between the ecu and ground continuity exists (not good).
Any help would be appreciated.
O yeah, i already searched for this topic in couple of forums.
Old Jun 11, 2007 | 06:19 PM
did you reset the ecu after the o2 sensor was replaced.
a friend of mine has a 2000 contour that had his cel come on. it was a bad o2 sensor, so he replaced it but the light stayed on. i reset the ecu and no more light.
Old Jun 11, 2007 | 06:42 PM
knives123's Avatar
Yes, i did. Many times. I also check the the voltage on the o2 sensor, and it was reading between .3 to .6 volts. While running at 2000 rpm under no load.
Old Jun 11, 2007 | 08:40 PM
BigVinnie's Avatar
If you are showing continuity on the ground wire I would suggest just applying a new ground somewhere to the chassis.
Old Jun 12, 2007 | 09:43 AM
knives123's Avatar
The single wire from the oxygen sensor has a shield around, i believe, which is grounded and the sensor uses its body as ground to close the loop. So, i don't know what you mean by getting a new ground? You mean to take out the shield ground?
Old Jun 12, 2007 | 09:46 AM
BigVinnie's Avatar
Never mind I thought you were talking about the second sensor that plugs into the harness after the CAT. I missed the part where you said front sensor...
Old Jun 12, 2007 | 03:08 PM
knives123's Avatar
Actually that gives me an idea, not the new ground. But i can remove the grounded shield for wire and have no contact with the chassis ground.
Old Jun 12, 2007 | 03:26 PM
BigVinnie's Avatar
Let us know if your idea works...
Old Jun 13, 2007 | 06:02 PM
knives123's Avatar
It worked. The ground terminal on the engine that is used to ground the shield for the green wire (oxygen sensor wire) was removed and engine light disappeared. I'm just going to cover the terminal with electric tape and the won't have any problems with it, hopefully, since it is only a ground for the shield.
Thanks for the tip bigvinnie.
Old Jun 13, 2007 | 09:14 PM
BigVinnie's Avatar
Hey man it was all you. I just know when grounds go bad to apply a new ground wire...
tallic_red240sx
Sep 4, 2006 10:33 AM
uvamosk
Aug 12, 2005 07:31 PM
NismoKa
Sep 9, 2004 06:40 PM
rahdog76
Jun 26, 2004 10:40 AM
bleach8484
May 14, 2004 07:44 AM
