EGR temp sensor
Old Feb 3, 2005 | 11:04 AM
ca177or4's Avatar
EGR temp sensor
i checked alldata for this part but it doesn't give a very gud description bout where it is. does anyone no where it is....i no its next to the intake manifold on the exhaust passage but i cant find it. oh yah i got a KA DOHC.
thx
Old Feb 4, 2005 | 03:44 PM
wikd240's Avatar
i have my whole motor outta the car with the head sittin up on the bench... egr is exhaust gas recirculation valve... that is on the back of the head between the head and the intake... i dont see any temp sensor there at all... i have a vaccume valve and the egr valve itself... with no wires in it whatso ever...
the only electrical connection i have is on the acc valve under the intake manifold...
Old Feb 4, 2005 | 04:55 PM
ca177or4's Avatar
naw i no theres a temp sensor...i pulled a code for it....even checked wit my master tech at work n he said theres one...jus gotta find it...next to intake manny on exhaust passage. its prolly in da middle.
Old Feb 9, 2005 | 10:17 PM
ca177or4's Avatar
r u sure vinnie.....i thought that was the aiv system....the black box nex to the air filter.....alldata says its next to the intake manny.....im very confused now....check engine lite has been on for a long time now? pulled codes and it said it was the egr temp sensor.
Old Feb 9, 2005 | 11:20 PM
BigVinnie's Avatar
OOps my bad man. I just took a look at my Actron code scanner book for OBD1, the code should be the same for OBD2. Supposedly you are throwing a code 35 Right?
There may be a leak. Or follow wire connection and replace the sensor at the top or at the bottom" can't really remember" of the EGR valve, also check to see if your wires are still intacked and not dried out. I believe the temp sensor is on the EGR". Again check connection and wire's. It can also be the EGR valve if need be replaced, first test, place the EGR valve in a bowl of water and blow air in to the outlet "use a long tube" to the mani. If you don't see bubbles in the water it will need replacement,"EGR valve could be jammed".
If your wiring is over 10years old it should be replaced, due to the extreme heat conditions under the hood. You can get the wires and sensor harness through www.digikey.com and it is cheaper than getting it at nissan. Hopefully that helps...... Sorry for the misguided info from the AIV.... I get the AIV, thermostat, and EGR confused "sorry that I didn't pay attention to the reading and that you mentioned EGR, I read to fast sometimes". Also since the EGR/BPT sensor also throws a code 32," for vacuum and valves".... I will delete the original post, sorry for the prior retarded misguided info. My bad I appoligize, I hope that this will help...........
Old Feb 10, 2005 | 09:54 AM
ca177or4's Avatar
hey its all good...at least u know wat ur talkin bout which is a helpful thing...and the code its throwin at me is a 32.....but i have vaccuum so im still confused.....the check engine goes on and off every now and then....its an intermitten problem that i cant pin point.....need to do this fast cuz i gotta do a smog check soon....very soon!
Old Feb 10, 2005 | 01:32 PM
BigVinnie's Avatar
Code 32 in the actron code scanner says: Exhaust GAS Recerculation Sensor- Bad EGR control valve, EGR control solenoid valve, Exhaust gas temprature sensor, Back pressure transducer(BPT), or canister control solenoid. Clogged vacuum port, Faulty vacuum lines, or valve sensor wiring....
From what I understand if your vacuum lines look good, then you need to replace the entire EGR/BPT... Takes to long to check alll the parts, and once one part goes faulty, the whole EGR begins to go faulty.
I just did this procedure myself at about 125,000miles.
Just unbolt the old and put in the new EGR/BPT cost relatively $90bucks, install takes about an hour, while you are at it replace all the cheap hoses anyway.
Do Not let a mechanic do it, they will charge you the 3 hour maximum requirement.
Also forgot to mention you will also want to check wire connections, they could be a little rusty, if so dipp the connection in a lube called anti sieze, prevents moisture from getting into your connection. It is usually used for light bulb connections.....
Old Feb 10, 2005 | 04:11 PM
ca177or4's Avatar
i no....i am a technician for FORD. still tryin to get the hang of the nissan parts. i didnt even no there was an egr temp sensor till i found out mine has one. ford cars dont. i wont deny i need help from u guys who no more bout the 240sx than i do!!!
u think ill have to get the intake manny out of the way?
thanks for the help....ill just change the egr valve
Old Feb 10, 2005 | 06:05 PM
BigVinnie's Avatar
OH no, don't tell me you work for Found On Roads Dead. Yeah it is a job though. You will find out that for an import Nissan builds cars powerful and reliable, with just as much torque, than there are donkey's. I think you will also find out that nissan equipment is a little bit more technical than ford parts, also making the engines more reliable than Fords.
Nissans are also simple fix it problems, I think you will have fun...
As for the mani dont remove it, or else you will get into a big pile of shiat. Then you will have to get new gaskets, and there is the chance that you could bust off the knock sensor in the process.
Old Feb 10, 2005 | 11:24 PM
ca177or4's Avatar
aight thanks.....n dont worry....ive never owned a ford myself....just fix them cuz i no ill always have a job!!! lol
Old Feb 11, 2005 | 08:52 PM
Re: EGR temp sensor
thx
Didn't you post this somewhere else already?!?
Old Feb 12, 2005 | 12:51 AM
ca177or4's Avatar
nope
Old Dec 6, 2005 | 05:14 AM
Cape 240's Avatar
Sorry to revive this AGE OLD thread ..
but I was wondering, Vinnie...
Where did you find the parts for $90.oo ?? The cheapest I can find is $120.oo and thats only fro the EGR Valve.
Old Feb 18, 2007 | 10:05 PM
om3ga's Avatar
Its on the lower portion of the intake manifold so drop the lower portion to get to it,its a small screw with a wire going off of it.Not even that close to the egr more in the middle of the lower intake manifold.
Hi Im Simon
Mar 28, 2008 04:32 AM
Tedzy
Dec 14, 2007 10:45 AM
BigVinnie
Oct 14, 2007 04:30 PM
rahzeek1
Jan 7, 2006 04:39 PM
vbgambini
May 4, 2005 12:28 AM
