gains from coolant bypass
Old Jun 25, 2007 | 12:54 PM
verumgero's Avatar
I now have a 1989 240sx fastback and I was reading about some mods for the KA engine and I was wondering what sort of gains I could expect from bypassing the coolant from the throttle body?
Old Jun 25, 2007 | 12:57 PM
+10whp at least.
no j/k it's a worth doing mod but with minimal gains. the egr block off will yield better gains but even then don't expect too much.
Old Jun 25, 2007 | 12:59 PM
verumgero's Avatar
this is going to sound noobish, but "egr"?
Old Jun 25, 2007 | 03:27 PM
re037's Avatar
exhaust gas return. both will help in throttle response mostly, but not much if any in hp gain.
Old Jun 25, 2007 | 03:39 PM
egr block off will cause your engine to run rich and will result in some hp gains.
Old Jun 25, 2007 | 10:42 PM
verumgero's Avatar
OK, I plan on doing the coolant bypass, but about the egr block off, where is this tube that needs to be blocked? Do you think you could take a picture of the engine with a little arrow pointing it out?
Old Jun 25, 2007 | 10:53 PM
http://www.ka-t.org/forums/viewtopic...t=egr&start=35
it's toward the bottom of the page.
Old Jun 25, 2007 | 10:59 PM
verumgero's Avatar
thanks for all the info
Old Jun 26, 2007 | 12:26 PM
BigVinnie's Avatar
I'd say 1 HP across the RPM range to increase acceleration. That it in a nut shell.
Old Jun 26, 2007 | 03:20 PM
Durdan's Avatar
coolant bypass doesnt do too much, but i noticed a 7rwhp gain on the dyno by blocking off my egr on my old twincam
Old Jun 26, 2007 | 10:48 PM
verumgero's Avatar
OK so this morning I bypassed the coolant and I installed a cone filter. I seemed to feel a gain in horsepower as I took it for a test drive, now I am not sure if that is just wishful thinking, but I think it did something. But I have to ask, why does it do anything? What all does this operation affect and why does it do anything?
Old Jun 27, 2007 | 05:44 AM
BigVinnie's Avatar
Intake charge stays cooler. Coolant is used to heat the TB when it's cold outside so that the butterfly wont stick when it's below freezing outside.
BigVinnie
May 12, 2007 09:12 PM
buyMEbeerPLEASE
Dec 21, 2006 10:48 AM
jcl666
Oct 12, 2006 04:21 PM
PissonH
Jul 5, 2004 07:19 PM
RoadblockTDX
Apr 28, 2003 02:41 PM
