gas smell
Old Aug 5, 2006 | 02:14 PM
pourinitup's Avatar
gas smell
when i drive it starts to smell like gas...what do you think fuel injectors? or somethin else
Old Aug 6, 2006 | 01:01 AM
dkdeleon's Avatar
check around your injectors for moisture after starting the motor.
it sounds like a leeking injector.
Old Aug 11, 2006 | 06:06 AM
NismoSpD20's Avatar
ive got the same problem but mine isnt the injectors cause i just did new o rings no leaks, but i sttill smell gas any tips
Old Aug 11, 2006 | 10:36 AM
Clearalbino's Avatar
could be your coolant temp sensor, those seem to go bad and will cause you to dump fuel.
Old Aug 11, 2006 | 05:39 PM
re037's Avatar
check fuel lines for leaks also. fpr, filter etc etc
Mika
Feb 5, 2005 03:50 PM
bradltl
Apr 18, 2004 10:15 PM
chwwilliam
Nov 27, 2003 12:01 AM
s13stillen
Jan 21, 2003 10:37 AM
KeVQ35
Feb 10, 2002 09:50 PM
