Which Gasket kit
Which Gasket kit
Now this is going to sound very obvious but i was wondering how different a gasket kit for an s14 ka is versus an s13 ka. The reason i ask is because i am going to put an s14 ka in my s13 and i switched over the manifolds and distributer, etc. and i wanted to get my manifold gaskets with the kit, but they will only come with a s13 ka.
So if the gaskets are that different i guess i just need to get the s14 kit and buy the other gaskets seperately.
Also, are the S13 and S13 ka crank shafts the same?
Thanks again, and i know the answer is obvious. but just figured id ask.
The only true difference between an s14 and an s13 gasket kit is that the valve cover/head for the s13 has an additional bolt location. S14 heads/valve cover dont use the additional bolt. So there is a slight difference between the valve cover/head. All the blocks are the same from 91-98 240sx KA24de's.
