idle troubles/rpm crash
Old Jan 10, 2008 | 10:45 PM
iceman4's Avatar
when i leave my car to idle it jumps around all over the map rpm wise. it goes anywhere from 1300rpm down all the way to 400rpm. also when i put in the clutch from anywhere above 3000rpm and let it go down to idle, it often stalls on me.
is this my fuel injectors? spark plugs? vacuum leak?
thanks a lot guys!
Old Jan 11, 2008 | 12:10 PM
iacv would be my first guess.
Old Jan 11, 2008 | 09:48 PM
BigVinnie's Avatar
Check all vacuum lines also, besides the IACV.
Your stalling issue could just be that you need a tune up, my engine use to stall when I would push down on the brake, and had a bad IACV.
Old Jan 12, 2008 | 03:21 PM
it is very possible that the problem is a vacuum leak, although something i've noticed over the years with different cars is that vacuum leaks have caused higher idling that 1300rpms. the vacuum leaks i've encountered have caused an idle of about 2k rpms.
just something i've noticed.
i second the tune up or at least check the dist cap and o ring for damage.
unit77
Feb 8, 2007 10:40 AM
doomcore
Dec 22, 2004 07:48 PM
irax
May 25, 2004 10:49 AM
-=coppertop=-
Nov 12, 2003 03:42 PM
240baja
Oct 29, 2003 02:35 PM
