Issue with cylinder #3
I'm in need of some help with my 93 sx, here is the problem and what I've done so far
When I start my car I have to give it some gas or it bogs, after that the idle is fairly stable at about 900rpm but the engine and car shakes. We've traced it to cylinder 3, with the car running we removed the plug for each injector, and the rpm dropped for each cylinder except #3. So here what we've done so far
New cap and rotor
new spark plugs
new injector
compression test (140-148-140-148)
we have spark, fuel and the injector is getting power
The car still bogs down at start up and shakes
Any ideas what to look for/try next?
I also posted this over at NICO, just want to get as many ideas as possible
New cap and rotor
new spark plugs
new injector
Your piston head and chamber is full of carbon, so it creates detonation and it vibrates/ bogs. I'll bog because its detonating and the computer turns it off to protect the engine. Sicne you got low compresion, prolly the oil has ben goign up the cilinder walls creatign carbon residue.
Try one of those cans of engine restore, do it in 3 oil changes, It really helps a lot.
onelove240
Mar 22, 2008 07:50 PM
Dounveeme
16
Jul 10, 2004 01:32 AM
