KA Head Flow Rates
Old Jan 16, 2008 | 12:37 AM
240-kid's Avatar
KA Head Flow Rates
Half Cut
Bench Flow Test
Valve Lift / CFM
Intake:
.100" = 99.3
.200" = 171.1
.300" = 223.4
.400" = 241.8
.500" = 243.6
Exhaust:
.100" = 75.8
.200" = 144.5
.300" = 173.9
.400" = 182.9
.500" = 183.6
Originally Posted by Valve Info
Intake -
Valve Diameter: 36.6mm
Valve Stem Diameter: 6.97mm
Valve Length: 101.32mm
Exhaust -
Valve Diameter: 31.3mm
Valve Stem Diameter: 6.94mm
Valve Length: 99mm
Head Volume (cc's) = 46cc's
Old Jan 16, 2008 | 06:16 PM
BigVinnie's Avatar
I'm assuming the flow bench test on the bottom is stock flow rate... Is this correct?
Old Jan 17, 2008 | 12:21 AM
240-kid's Avatar
Yeah, the top one had a Flow Bench error, so I need to remove it
Edited***
Old Jan 17, 2008 | 07:17 AM
BigVinnie's Avatar
Stickied!
I need this info for some before and after flow bench results on the head work I am about to do.
You can tell that flow can be a little better with the KA head at 99.3 CFM/ per .100" of lift it should have a CFM closer to 98~100CFM. Exhaust seems to be small diameter sizes for smog and scavaging reasons.
I would bet that very little head work needs to be done to the KA and it would have to do more with the valve diameter. I bet just a .040 diameter increase on intake and exhaust would make those CFM numbers go way up!
Old Jan 23, 2008 | 04:21 PM
240-kid's Avatar
Would it be smart to do a minor port and polish job and over size Int. valves .5mm over and exhaust .7mm over? or would that just not make sense, I figured this since the exhaust size doesn't flow so well.
Seems like 10mm of lift is optimal
Old Jan 23, 2008 | 06:02 PM
BigVinnie's Avatar
Just minor port, extrude, and polish you don't want to ruin the overall velocity of the runners. I think that improving the valve diameters would be much more critical.
I don't see why you wouldn't just do a .5mm all around, and enlarge the runners on the exhaust a tad more.
Size:  44.9 KBName:  KA24deheadporting2.jpg
Old Jan 23, 2008 | 09:40 PM
240-kid's Avatar
OK makes sense
added some more head info
JeffSchmitt
Apr 26, 2004 11:12 AM
chriswgsx
Dec 27, 2003 08:48 AM
spitz7985
Dec 14, 2002 10:11 AM
roneosf
Oct 17, 2002 02:59 PM
Import Fanatix
Sep 24, 2002 09:17 PM
