KA24 oil problems
KA24 oil problems
I am my brother's mechanic, and for a while now his car has been burning a lot of oil. There is always a residue on the rear fascia that the water beads on when it gets wet. The engine has about 130k on it. I was told by a local engine shop that it's probably the piston's oil rings that are froze/shot. I thought that it might be the valve guides, but he seemed to strongly disagree....
Does anyone have first hand experience with this issue?
Re: KA24 oil problems
Ya, a compression test is actually in the line-up of things to do along with the valve cover gasket set and the dreaded oil-pan gasket. I am going to check out the compression this weekend.
There is just some smoke on acceleration, not deceleration.....So, I pretty sure it's just the rings. Valve guides should be fine.
WhoDiddy
Feb 2, 2006 07:45 PM
ass15
Dec 17, 2004 12:15 AM
