a lil smokey
a lil smokey
hello
i just got a 92 240sx not to long ago
it came wit a custom made exhaust
piping straight from the downpipe
the catalytic converter was neglected
would this cause my car to run a lil rich and a lil smokey
it happens mostly at low rpms and pullin off u see the smoke
smoke comes from bad valve guides and seals... if the valves are not bad then you can reuse them... the valve guides are 2.50 in general... but you should not have to pay ny more than that per guide...
you get white blue smoke because you need a new valve cover gasket??? that would only be under the hood not comming out the exhaust pipe... and if you have a bad valve cover gasket why not fix it??? or do you like the smoke look???
bluish
i am losin oil too so i am burnin oil
i am gonna do a compression test tomorrow to see wat i can come up with.
make sure its not rings or nothin
hopin its jes the seals or something
but thing is i aint know how to fix it so i am relying on a good shop i go to to hook me up
yeah a leaky gasket is causing my engine to burn oil. And i also found out that i dont have a gasket connecting my cat and pipe. So i got one but im not puttin it in till tuesday along with wit my vc gasket.
