Quick S13 to S14 Cam Install Question
Old Apr 27, 2006 | 04:49 PM
All Mighty KA-T's Avatar
Question Quick S13 to S14 Cam Install Question
Ok, i'm going to install the S13 cams into my s14...... i'm going to run the :
248 Intake & 240 Exhaust Setup
since this will be the best power setup for the KA......anyways.
My Question is...... do i need to pull any teeth on the cams or can i just bolt them back up the same way as the stock s14 cams were set on??
Old Apr 27, 2006 | 11:32 PM
miked808's Avatar
Since the S13 is 240 Intake 248 Exhaust that means you are gonna swap them around. Take a picture or a mental note of the position of your stock cams and using a sharpie mark on the chain the link locations of the marks on the Intake and Exhaust Cam Sprokets. Put the S13 Exhaust Cam on the S14 Intake side and line up the Dot on the Sproket with the Mark you made with the Sharpie. Than turn the Cam counterclockwise 4 teeth for Upper End HP or my personal favorite 3 Teeth for low end Torque. Than you Take the S13 Intake Cam and put it on the S14 Exhaust side and line up The Exhaust Sproket with the mark you made on that side than turn Clockwise 4 Teeth. Now I've never put a 240 duration cam on the Exhaust side so double check other places to make sure it's 4 Teeth clockwise. When its done look at the orientation of the Lobes and see if it matches the way the original S14 cams looked. Meaning when you started the swap, the Engine should be at TDC and the No 1 Cylinders Cams should be pointing almost directly away from each other.
Old May 1, 2006 | 11:01 AM
dkdeleon's Avatar
here are the correct cam and sprocket install.
Attached Thumbnails Quick S13 to S14 Cam Install Question-sprockets-cams.gif
Old May 1, 2006 | 12:18 PM
miked808's Avatar
Never seen that diagram before but it sure can save some Headaches.
Old May 1, 2006 | 07:02 PM
yes, that will help out alot....thanks
P.S. what cam setup is that for..... the stock 240/248 setup?
Oh and i have read in another forum about a 248/232 cam setup.....what cams are those off of?
Old May 2, 2006 | 04:10 PM
barcode's Avatar
the 232 is the stock cam in our cars we got 232/232, so that would be the exhaust cam from the 91 S13 and our stock exaust cam.
Old May 3, 2006 | 09:44 PM
dkdeleon's Avatar
It is for the 1991 ka24de.
Old May 4, 2006 | 12:40 PM
redpotatoes's Avatar
240sx cams
Intake/Exhaust
232/232 is from 95-98
240/248 is from 91-94
This might help you also, 95-98 with 2x248 exhaust cams, -4 on the intake side.
Old May 4, 2006 | 10:25 PM
re037's Avatar
is this the same for the s13 goin 248 intake? 4 teeth?
Old Jul 17, 2006 | 06:41 PM
sav180's Avatar
i was thinkin to go with the 2x248 for my s13..so would it b the same
gunline_boss
Aug 11, 2005 12:26 AM
jcl666
Jun 8, 2005 11:19 PM
JDMxDrift
Apr 14, 2005 12:11 PM
Fyre240Sx
Nov 1, 2004 05:54 PM
specialk22
Dec 12, 2003 10:09 AM
