s13 cam install into s14
Old Jul 21, 2005 | 12:47 PM
gunline_boss's Avatar
i did the s13 cam install and now my idle is really messed up, i aligned it at tdc. My intake cam was pointing a bit higher up than the exhaust cam.
thier are 7 links between the circle indents on the sprokets and i installed at tdc so i dont know what went wrong. my idle is very rough 900rpm and slowly drops to about 700 and struggles to stay alive.
anyone have any advice
Old Jul 21, 2005 | 08:08 PM
Sieji's Avatar
Whachu mean by struggles to stay alive?
... the Idle for 240s should be about 700-750 rpm. If you're positive ur cam install was clean... try checking your vacuum lines, and playing with ur distrubitor timing; till it idles straight...
If it doesn't work out, my apologies
I'm a backyard mechanic...
~Eji
Old Jul 22, 2005 | 03:22 AM
wikd240's Avatar
i would say that the cam timing is off... when you did the cam install did you pull the distributor and turn the crank untill all the timing marks were lined up that you could see??? beings how you can only see the upper timing marks... if that is not the case then what i would do is pull the distributor and the cams and start over again... make sure that the one mark for the lower timing chain is in the right place at top dead center... as soon as you get the lower timing chain in the right place reinstall the cams again using the 3 silver links and the 3 timing marks... one on the lower gear and one on each cam... then reset the distributor and make sure it is pointing to the number one position on the cap and try again...
Old Jul 24, 2005 | 05:20 PM
cool i fixed it
Old Jul 24, 2005 | 11:21 PM
tryiian's Avatar
tell us how, so this thread is useful for someone who searches on it. Using the reset crank pulley, dist, and realigning cams method?
Old Jul 26, 2005 | 07:38 PM
my cams werent lined up properly so i re did everyting just remember always check if its at TDC it tends to move sometimes
and i recommend puttin s13 cams into a s14 i feel more power all the way to redline its like v tec
Old Jul 26, 2005 | 08:49 PM
Preston's Avatar
Flame On! lol
Old Jul 29, 2005 | 03:08 PM
BigVinnie's Avatar
More like continuous VTEC from 1200RPM all the way to 6800RPM..... LOL
Man it will guzzle gas, but it shure does kick some ***!!!!!!
Old Jul 29, 2005 | 10:40 PM
Chiefgmsr's Avatar
Can you use any s13 cam or is this more focused on 91 and 92?
Old Jul 29, 2005 | 10:43 PM
BigVinnie's Avatar
91-94 cams are the same. PDM racing even specify's that the cam lobe and duration for 91-94 are the same.
Old Jul 29, 2005 | 11:21 PM
Chiefgmsr's Avatar
Thanks fo the info
Old Aug 10, 2005 | 12:29 AM
tryiian's Avatar
Hey Vinn, don`t you mean 91-93? iWas pretty sure that the 94 (the verts) got s14 232 cams.
Old Aug 10, 2005 | 01:39 AM
BigVinnie's Avatar
My bad your right.........
I get lazy and don't give a crap too correct my mistakes half the time..........
Old Aug 11, 2005 | 12:26 AM
tryiian's Avatar
np man, that`s what the forum`s all about.
All Mighty KA-T
Jul 17, 2006 06:41 PM
jcl666
Jun 8, 2005 11:19 PM
JDMxDrift
Apr 14, 2005 12:11 PM
Fyre240Sx
Nov 1, 2004 05:54 PM
specialk22
Dec 12, 2003 10:09 AM
