slave cylinder replacement
Old Mar 30, 2006 | 06:29 PM
portion's Avatar
how hard is it to replace?
it seems simple enough?
is it just unbolt the 2 bolts holding the slave cylinder to the tranny, then take it out and undo the brake line?
or its more to it?
how is the rod part hooked up?
is it just in a groove? never seen how its actually connected?
any help would be appreciated thx
Old Mar 31, 2006 | 06:23 AM
CowboyTurbo's Avatar
just remove the two bolts. If you can't get the new one on, just jam a screwdriver into the tranny and ply fork to give you a little bit of room (be careful not to break anything). And bleed your lines thoroughly when done.
jt1583
Oct 20, 2005 06:27 PM
yektik99
Mar 28, 2005 09:19 AM
cticknor666
Sep 25, 2004 09:08 AM
spoolin240
Apr 16, 2004 06:14 AM
Supranatural
Nov 20, 2003 12:09 PM
