Strange revving issue
Old Aug 27, 2006 | 06:44 PM
epp_b's Avatar
This is going to be a little difficult to explain, but I'll do my best...
I have a '95 240SX SE. When I rev my engine abruptly from idle (about 800 or 900 RPM), everything shutters and shakes for a second. But, if I can rev apruptly from anything above about 1,500-or-so RPMs and it responds just fine. If I rev the engine more smoothly (not slowly, but not abruptly either) from idle, I don't get any of this shuttering.
Is this normal?
Old Aug 27, 2006 | 07:11 PM
LITTLEDEVIL S13's Avatar
ever done a tune up on this vehicle ?? how long have you owned it? ever cleaned out the maf before? got a good clutch? running good fuel?? you gotta ask yourself alot of questions cause there could mulitple things wrong ya know but only cause one symptom.. also fuel filter? and throttle cable... you could try any of these to figure it out.... hope that helps point you in the right direction....
Erik
Old Aug 27, 2006 | 07:39 PM
epp_b's Avatar
So far I've...
- I checked and topped up all of the fluids as necessary
- changed oil and oil filter
- changed spark plugs
- changed air filter
I just got it about a week ago. Other than this, it's been running great. I've had no unexpected problems and I've already put nearly 1000 KMs on it.
No.
got a good clutch?
The clutch is on it's last leg, it's probably never been replaced before (the car has 171,000 KMs).
running good fuel??
Octane 91.
Thanks for the help. I'll probably have to take it to a garage to find out what it is, because I'm no mechanic. I was just wondering if, perhaps, this was a common issue for which the remedy is known (I also figured that searching the forums for this problem would be difficult).
Old Aug 28, 2006 | 12:36 PM
epp_b's Avatar
I showed this to my dad who suggested that it could be the fuel injection timing could be off. Does this sound accurate?
Old Aug 28, 2006 | 12:46 PM
re037's Avatar
sounds like time for some seafoam action
Old Aug 28, 2006 | 01:08 PM
epp_b's Avatar
You lost me there...
Old Aug 28, 2006 | 01:49 PM
Go to your local auto parts store and ask them for seafoam, its like a miracle liquid lol
Old Aug 28, 2006 | 04:09 PM
Guys thats def a great idea i did this no lie to my car about 2 weeks ago, but its basically this "miracle mechanic in a can" that can added to clean your fuel system, oil system, and you can also clean out your intake and some what exhaust system by vacuum bleeding with a hose in the can hooked to a (after thorttle plates) vacuum source ... and hold the throttle to keep it running during this step... it will smoke for a while after this procdure, but just drive the car about 3 miles and it will go away.. but yes SEAFOAM i def. like this stuff hope this helps with everthing...!!
Erik
onelove240
Mar 22, 2008 07:50 PM
redpotatoes
Dec 22, 2005 09:00 AM
icon1
Oct 24, 2005 11:59 PM
luv_2_xl_er_8
Jan 18, 2004 02:03 PM
drpepper180
Nov 22, 2002 09:55 AM
