Thermostat
Thermostat
Ok, I was driveing my 90 240 the other day and the heat was not working and the car over heated. I popped the hood and saw coolant spraying out from under the thottle body. I pull everything off, look at all the hoses and they all look good, no holes. So my question is, if the thermostat was stuck 1: would it keep the heat from working in the car, and 2: where the f*ck is the thermostat? The little hoses under the thottle body are a pain to. almost impossible. Any help is appriciated guys!
Also, when the heat works, the car doesnt over heat?!?!
The thermostat is located to your bottom right hand corner, directly under the throttle body. It's super easy to change, just make sure you got sealant epoxy, or a thermostat gasket when putting it back together.
Originally posted by Juicedgsr95
Thanks for the reply. Since that post I have already taken it to the shop to have it replaced. Only thing is, they raped me on labor. oh well....
