valves???
thanks for the info.
heres my goals with the 240 i want to eventually put a turbo kit on it so which size of valves would you suggest on it? alsu what timing set do you guys suggest. also i need a new clutch the one in my car is toast.
thanks again guys
thanks again guys
having the machine work done to install even the .5mm oversize valves is going to cost a grip... but if you got the cash to do it then get the biggest valves they make and stuff them in there... get a serious port job while they are doingthenew valve openings...
as far as the timing set... i have found that using genuine nissan timing chain kits is the best... cost more but still worth it in my book...
cant help much on a clutch because i driveautomatics....
how power u plan on making? if its not a crazy amount like over 400 or something then a stage 2 will be fine, ive been running an exedy stage 1 on my car for a good 6 months and its still holding up well, im roughly 300hp and do a goodbit of drift/autox...so a stage 2 would be good up to around 400hp id say...but if the car's gona be stricly drift then buy a stg 3 or 4..
actually with it being a hicas car i plan on doing autox with it. i dont really plan on going over 400 with the 240 thats what my supra is for
im also looking for a good how to on porting and polishing my engine.
thanks again guys
im also looking for a good how to on porting and polishing my engine.thanks again guys
