Fuel Door won't open on s13
Old Jun 21, 2007 | 05:49 AM
allanH's Avatar
Tried searching around the internet and a few 240 forum sites, but not having much luck.
Went to get gas this morning and the fuel door wouldn't release. Is this a common problem? Is there an easy fix? Is there another way to open the door.
Have a 93 240sx.
Thanks
Old Jun 21, 2007 | 06:59 AM
USMCDrifter's Avatar
I'm pretty sure you can just pry the thing open with a screw driver or something and it shouldn't damage your paint for the meanwhile, what's most likely happened is either your cable isn't drawing enough tension to actually open the gas door (kinda like the hood cables do on BMWs after a while) so it probably just either needs to be adjusted (if that's possible) or it may need to be replaced. I'm sure that's it, because it's not electronic, it's cable driven, now it feels like, when you pull it, that the cable just draws the door open so I would check into that.
-Stig
Old Jun 21, 2007 | 08:03 AM
just get rid of the whole system and manually open it
Old Jun 21, 2007 | 08:09 AM
Well . . . . .yeah . . . . .if ya wanna be simple about it
-Stig
Old Jun 21, 2007 | 03:40 PM
clubredsilvia's Avatar
^^^ thats what i did. i just ripped the cable out and now i have a bolt that i stuff in the hole behind the wheel well to keep the door closed. Mine didn't work either; when i wanted to open it up i had to push it so hard that it felt like it was going to go through the floor.
Old Jun 21, 2007 | 03:43 PM
dude look behind the door and move the spring. after that it will be an old school open and close style tank.
fanmanflex
Oct 25, 2009 05:44 PM
hjohnson40_79
Sep 28, 2007 05:43 PM
redline88
Jan 17, 2006 09:31 AM
Graphfixz
Oct 24, 2004 07:14 PM
Jedi Mind Gamez
Jul 20, 2004 01:18 AM
