Blackzenki's back in black, round 3....
Old Jul 21, 2009 | 05:08 PM
  #241
platinums are ok, just as iridiums are ok, but iridiums are still overrated. longer life is about the only benefit that will apply with these engines boosted or not so go with what you like.
Old Jul 21, 2009 | 09:05 PM
  #242
BlackZenki82's Avatar
yeah.....
Old Jul 22, 2009 | 01:57 AM
  #243
nice toys
Old Jul 22, 2009 | 06:33 AM
  #244
eh, the bike belongs to my buddy Ryan... i wish it was mine... LOL
Old Jul 23, 2009 | 07:48 PM
  #245
so i got wicked tired of my headlights looking like this....
and i decided finally to do something about it... so i went to Auto Zone, and scooped this lil bad boy up... and got to work...
pulled my headlights off, cause it was dark outside, and well, I'm impatient as **** and can't wait to do anything, and brought them inside and set up shop... here's the "before" shot... with and without flash to show clarity...
and the afters.... who needs German glass???
tomorrow I'm going to spray a coat of clear on the lenses to keep the yellow from coming back, as i hear that's a problem with doing this...
and i'll snap a shot or two of them actually ON the car in the daylight...
Old Jul 23, 2009 | 09:30 PM
  #246
got bored and did my turn signals too...
the difference is negligible...
before...
after...
see, not much of a difference, but hell, in the details is where it counts... at least now it's a nice smoooooth surface for when i paint them, and the corners amber...
Old Jul 24, 2009 | 08:18 AM
  #247
so, not even 5 minutes after waking up this morn at 10:35, i, like a kid, ran outside to get my lights on....
as promised, installed photos....
Old Jul 26, 2009 | 12:57 PM
  #248
everyones detailed up... couple things hanging out with the gray car tho... dropped exhaust, front bumper just stuck on, and the VLSD dropped...
i also spent half the morning tweaking, banging, and adjusting the front and rear end of the black car... it wasn't "perfect" before, so i had to move some things around... now it back to OEM straightness with 3/16" gaps all around... front is a still a bit off but oh well...
now the louvers on my Kouki tails line up perfect...
also, i got tired of the bad serial port on my Nistune, and i figured, since i got a new lap top, i might as well get the consult port like i like it...
work station...
final answer....
and i got a few more things coming in the mail....
CAS...
FReddy extra capacity oil pan...
Adjustable cam gears...
Old Jul 29, 2009 | 09:59 AM
  #249
hitting the track this weekend... any guesses on what this **** will run in the 1/4?
my guess is a mid 12's probably a 12.5-12.7 @ 110+
on my "stock" setup, IE MAF, injectors, bolt ons, i ran a 13.3 @ 108.3MPH with a serious bog off the line (damn fidanza), and spining 3/4 of 2nd, and 1/2 of 3rd, so i think, even on that set up, if i could have gotten my launches down, and tire spin under control, i could have hit a 12.9 EASY if not less... i was running 16lbs psi, this go round, i should be around 18-19lbs PSI on my t28, Zmaf, and 550s....
guesses?
Old Jul 29, 2009 | 10:27 AM
  #250
Good luck. low 12s would be nice at 18-19lbs
Old Jul 29, 2009 | 10:35 AM
  #251
low 12's would be bad ***, i hope i can get bogging and traction under control... i read with a fidanza, you have to launch higher, and shift faster, as it loses inertia... before i was launching at around 4.5k, this go round, i'll try for around 5.5-6k.... i have RAS now, and raised my rev cut to around 7.8k, and my turbo is built to be efficient throughout the RPM range, so hopefully the extra 600rpm can give me what i need... although i'll prob still shift around 7kish...
Old Jul 29, 2009 | 02:57 PM
  #252
240smoke's Avatar
Damn, your car is very sexy. I like that your always doing something to it. Whether its something hard or just polishing your headlights. Gives me something to read when I am bored.
Old Jul 29, 2009 | 06:17 PM
  #253
thanks smoke!!!
some guy on another forum compared my build thread to his daily newspaper, cause he knew everytime he got on said forum, my build thread would have something new... big or small....
might be trading my megan street coils for a set of HKS Hiper D's...we'll see...
Old Aug 2, 2009 | 04:33 PM
  #254
never made it to the track.... was too friggen hot.... you had two choices of how you wanted to be in the meets parking lot.... sunny side up, or over easy...
so i just went home and lost my starter a mile before i got home.... NICE....
good news tho, got a parts list waiting for install
new SR starter
FReddy oil pan
Circuit Sports inner/outer tie rods w/boots (last peice of stock suspension that needs replaced)
Nismo motor and tranny mounts (yes ryan, i will get them)
Innovate LC-1 Wideband (finally i can datalog AFRs with my NIStune)
KOYO radiator (just installed)
Vision Motorworks adjustable cam gears (will put on HKS Step 1 cams if i can get them off of ryan)
OEM SR20DET fan shroud (OEM bits FTW!!!!)
HID's (will look OK in my restored lenses)
new Koyo w/new Samco hoses in.... ordering a Nismo thermostat, and a GReddy/Nismo 1.3 bar radiator cap..
HID's installed... yeah i know, looooooooong grain rice, but **** it....
a shot of these cam gears i have, and my FReddy oil pan...
and a Dodge Viper i was ****ing around with on I-75...
that's all for now i think....
Old Aug 2, 2009 | 09:17 PM
  #255
240smoke's Avatar
did you know that you can rebuild your started with a SOHC KA starter? I did it. It was pretty easy and saved me some money.
