the little engine that could
Old Jul 16, 2009 | 09:33 PM
  #121
at this point i don't plan on making any adjustments, but then again i did only plan for the basic, intake, header, exhaust, and call it a day. so at least for now the stock maps will do. i also have it on good authority that the stock maf and injectors will do fine for about 225ish hp, and since this is ment to be a dd, i don't expect much excesive reving to be needed.
Old Jul 17, 2009 | 08:17 AM
  #122
BigVinnie's Avatar
Meeeh that 225ish number is ill represented. Depends on duty cycle, not HP. I've blown out 2 of my 4 injectors at 162WHP, or what would be about 205 Crank HP, at 6500RPM peak power.
Old Jul 19, 2009 | 03:17 PM
  #123
hatrick6's Avatar
always love to see a NA KA build
also, why did you go with a lightened steel drive shaft over an aluminum one?
Old Jul 19, 2009 | 04:23 PM
  #124
long story short, i got a good deal on it, not great, but good.
Old Jul 31, 2009 | 05:37 PM
  #125
for awhile now i've suspected that there was something wrong with my wiring. today i saw that there was in fact something wrong. i took the dash off and started looking at my harness. here's a close up of what i found, at the left you'll see several wires fused toge there, at the right a single exposed wire, with current running though it i might add. so for about 9 years i've been driving around with a potential fire hazard.
Old Jul 31, 2009 | 10:16 PM
  #126
SmokedZenki's Avatar
wow man u got lucky! good thing you found that now and not while going down the road and hit the wrong bump.... so hows your car coming lately?? any updates? other than your massive wiring mess?
Eric
Old Aug 1, 2009 | 07:20 AM
  #127
BigVinnie's Avatar
wow I am willing to bet that has been like that since the car came out of production, possibly some pinched wires.
Are you going to use some liquid electrical tape? Or are you going to replace and splice?
Old Aug 1, 2009 | 03:28 PM
  #128
progress has been slow becuase for a number if reasons, but mainly because a driveway in +100º weather is not my idea of an ideal work environment. but i have made some small changes to the appearance of my front bumper. i did this because at highway speeds i felt a strong updraft. i'm still not finished, but this basically what it will look like.
as for the wiring problem, i traced it to the source which turned out to be the room lamp wire. only that wire was completely burnt so it's the only wire that will be getting replaced. the rest have some small exposed parts which i'll apply some liquid tape (black pvc glue) to. here are some more pictures of the harness.
Old Aug 1, 2009 | 09:15 PM
  #129
damn dude.... yea i remember reading that they used some ****ty wiring on certain years to cut cost... you are not alone. I had self inflicted issues under my wheel well.
Old Sep 13, 2010 | 07:48 PM
  #130
so after about a decade of faithful service, my battery gave up the ghost. it's a day i dreaded but also awaited because of the possibilities. i've always wonders if a riding mower battery would actually crank my engine or not, well it does.
Old Sep 16, 2010 | 05:04 AM
  #131
hahah send it off like you would that of a warrior... fire grave.
miatex
Nov 14, 2003 03:52 PM
leiferik1
Aug 29, 2002 06:20 PM
Daunttless
Feb 25, 2002 11:20 PM
Biohamhock
Feb 14, 2002 01:05 AM
Ben
Feb 10, 2002 09:27 AM
