Painting Interrior
Old Feb 17, 2005 | 06:54 PM
Darchangel's Avatar
Painting Interrior
So I wanna change my interrior color...right now, it's black (as are most 240's stock) but I'm getting my exterrior painted yellow (unless I change my mind) but I wanna change my interrior color. I figure it would probably be cheaper to "DIY" but I wanna do it RIGHT. How do you suggest I do it? What kind of paint? Coating over top? Primer?
I just need some answers plz
Old Feb 19, 2005 | 02:07 PM
yellow goes in and out of style. personally i like green and white 240s. they have certain paints just what ur lookin for at like autozone and whatnot. just read different cans at the store
Old Feb 19, 2005 | 02:45 PM
homer240sx's Avatar
try select products. i wouldnt use anything from any local parts store or you will end up with that rice boy spray paint look.
Old Feb 20, 2005 | 10:51 PM
djradam's Avatar
i spray painted some interior panels with regular flat black (or semi gloss). did maybe 4 coats and looks just like stock.
you might have good luck with a plastic paint so it fuses or whatever, but i think colors are limited.
Old Feb 21, 2005 | 11:42 AM
Darchangel's Avatar
wikd240 - By interrior, I dont mean seats....thats what...near impossible? lol
thanks guys...I'll let ya know if I even go through with the interrior
Old Feb 21, 2005 | 04:50 PM
chiroke's Avatar
yeah i think they make special spray paint that sticks to the vinel( i cant spell!!) my friend did it to his car it was a decent job, but up close u can see some drops so be carefull
Old Feb 24, 2005 | 03:24 AM
wikd240's Avatar
there is a honda accord that a friend of mine owned... he painted everything... encluding his carpet... was a semi nice job... after 6 months you could tell it was painted tho... i know this might be a sin but here are some pics of my old integra show car... only the plastic was painted in the interior... everything else was done by a shop in socal called extreme deminsions...
p.s. the blue accord that you can just see the front end of is the one with the whole interior painted...
Old Feb 24, 2005 | 02:46 PM
djradam's Avatar
on my friend's crx he took SHOE DYE to do the vinyl. i don't think it works on plstic, but he had a lot of parts done. so that could work on whatever is vinyl.
if you painted/dyed your carpet / seats, wouldn't it wear off????
Old Feb 28, 2005 | 01:44 AM
toycar's Avatar
for painting the plastic pieces use krylon fusion. that shet works good. for everything else take it to an upholstery shop.
Old Feb 28, 2005 | 05:06 AM
smokey240sx's Avatar
Make sure before you start spraying on paint you clean it first with rubbing alcohol and spray. Go to the local part store and pick up some can of Bulldog adhesive promoter. That will give your vinyl a better contact surface and flex.
Old Mar 4, 2005 | 12:11 AM
bullet23's Avatar
I got a can of the vinyl paint from AutoZone and used it on an old honda accord i have laying around and it looked great as far as i can tell. now i just hope that it stays up with time.
cd1921
Jan 15, 2005 11:43 PM
Matino31
Sep 26, 2003 12:45 PM
EkztremeRedline
Mar 17, 2003 08:55 AM
clikzip
Jan 28, 2003 10:12 AM
Dapper-D
Oct 21, 2002 05:06 PM
