removing a turbo PLEASE HELP!!!
Old Dec 22, 2008 | 10:22 AM
mr_canedo's Avatar
have any of you guys tried removing a turbo manifold along with the turbo its giving me a head ache. i'm trying to replace a broken bolt on the manifold and i need to change a gasket from the turbo to the manifold and so far it's hasn't been an easy task.
Old Dec 22, 2008 | 01:52 PM
HKST04Z's Avatar
should be an oil return line, an oil feed line, and a coolant line on the turbo. after that you should be able to unbolt the manifold. along with the turbo
Old Dec 22, 2008 | 04:16 PM
yea. bro.......... take your time look at it and disassemble it........ its no science to it you will have to approach it from many angles. top and bottom
Old Dec 25, 2008 | 12:37 PM
mr_canedo's Avatar
thanks, so far most of it is off it's just that there are a few bolts that where hard to get out i just need to get a last bolt from the line inside the turbo
Old Dec 25, 2008 | 04:41 PM
good stuff.. just to let you know................ the metal water/oil line will require you straighten the fitting out before screwing the banjo bolt back in. when you began to finger the bolt in, don't go crazy when it doesn't go in the first time.
personally what i do is LIGHTLY!!!!!!!!!!!!! bend the head of the banjo section straight a little bit so that there is not an angle to it. the best thing do to is invest in some braided line. Its flexible and you will not have to deal with the annoying hardl-ine.
Choppa'
Sep 6, 2005 03:21 PM
Waynehead05
Jul 27, 2005 12:05 PM
carl
Dec 31, 2004 03:56 AM
Drift-Obsession
Nov 12, 2003 04:15 PM
