camber correction on an s13
Old Apr 26, 2003 | 10:52 PM
brodie's Avatar
i just dropped my s13 1.5 inches all the way round a few months ago and my camber problem is starting to affect my wet weather driving, anyone know of a good/cheap camber correction kit?
Old May 17, 2003 | 06:44 PM
Jonas's Avatar
the rears should be adjustable somewhat, but other than that go to www.nopi.com and they have correction kits for the front for like 40 bucks i beleive. i have a major camber problem so iam going to end up spending about 400-500 properly fixing it.
Old May 17, 2003 | 06:58 PM
rudeboy's Avatar
how do you adjust the rears?
Old May 18, 2003 | 12:17 AM
alan-n's Avatar
I've looked into this also, and haven't the rear end of the car until I get adjustable upper arms.
The upper arm - subframe bolt is an eccentric bolt and allows for +- 0.75 degrees of camber supposedly. I haven't bothered with it myself and don't think that is enough adjustment at all even though I'm only lowering the rear end 1".
Old May 18, 2003 | 07:49 AM
rudeboy's Avatar
time for camber plates...i was really curious as to how much adjusabliity there was in the rear.....
Old May 18, 2003 | 10:02 PM
brodie's Avatar
just found out that PDM racing and GMP performance (here in charlotte) both carry decent camber correction kits for the s13 the GMP kit i think is about $20 for the front and the same for the rear. PDM racing kits are a bit more expensive but they are sold by a company that deals with 240's regularly so i dunno but thats what i have come up with
Old May 27, 2003 | 11:46 AM
Jonas's Avatar
these are my tires after lowering it 3 inches.
Old May 27, 2003 | 11:47 AM
Jonas's Avatar
fronts
Old May 27, 2003 | 11:48 AM
Jonas's Avatar
i played around with the rear suspension, and it doesnt realyl fix the camber that much, for now i only need a camber kit for the rear...i think nopi.com had some for like 30 bucks or so. i really need them in the rear though.
Old May 27, 2003 | 01:23 PM
Justin.b's Avatar
The fronts can be adjusted with the eccentric bolts that Don sells at www.pdm-racing.com . They work and they're much less expensive than camber plates and you don't have to introduce the harshness of pillow ball upper mounts.
The rears can be corrected with the Whiteline eccentric bushings from PDM, or with adjustable rear upper links. The adjustable links can be found at www.heavythrottle.com and I think they sell for $300+ / set. You can also slot the bolt hole in your suspension link and gain a little adjustability that way.
Jonas, why did you lower your car 3"? Please tell me you've got shortened strut/shock bodies.
-Justin
Old May 27, 2003 | 03:28 PM
yea i was wondering around pdm's site and i was ganna those eccentric bolts. u beat me to it
Old May 31, 2003 | 06:09 PM
Jonas's Avatar
-Justin
3in in front and actually 2 out back/.
M3thod_Man
14
Oct 30, 2003 10:03 AM
240duffman
Sep 30, 2003 07:28 PM
LigouriRd
Sep 11, 2003 07:12 AM
drnovascotia
Aug 11, 2003 07:39 AM
240duffman
13
Jul 28, 2003 04:34 PM
