Camber correction
Old Sep 11, 2003 | 07:12 AM
LigouriRd's Avatar
Camber correction
Ok, please dont flame me, I did a search and didnt find enough information.
Anyhow
I have a set of H&R sport springs which should give the car a 1.3" rear and 1.4" front drop. Now after I installed them I had 1.5 degrees of front and 3 degrees of rear camber. I wont destroy my new tire, so I removed them. Yeah I ordered a front camber correction kit from Eibach but the bolt is tiny, I think its the wrong part.
I have seen adjustable rear upper arms, any suggestions (JIC are expensive)...Kazama (see Jspec.com) mabye? I looked at whiteline bushings but two sets only corrects up to 1.5 degrees.
Are there any adjustable upper pivot block mounts that fit OEM struts. I have emailed countless vendors and have no responce. I could use camber bolts but i would like to be able to adjust the camber a the track (autox) if nessasary.
M3thod_Man
14
Oct 30, 2003 10:03 AM
240duffman
Sep 30, 2003 07:28 PM
drnovascotia
Aug 11, 2003 07:39 AM
240duffman
13
Jul 28, 2003 04:34 PM
brodie
May 31, 2003 06:09 PM
