ebrake light wont turn off
Old Oct 2, 2005 | 03:34 PM
larryw's Avatar
do any off u have this problem? idk..this has only started recently after i started tracking the car..and the light will stay on for long periods of time and go off for like only 10 seconds and come back on..i checked the brake fluid level and its right in between the min and max point..check the rear brake pads..its pretty worn but not bald yet..could it be the pads? thanx for all input!
Old Oct 2, 2005 | 06:42 PM
Preston's Avatar
Check the actual metal piece that triggers the light. It's on the bottom of the ebrake where the wires go to. At the end of a screw is a metal piece. When it touches the metal with the wire on it it triggers the light. Check and see if that piece is loose or in constant contact with the light.
Old Oct 3, 2005 | 05:48 AM
2fast4y0u's Avatar
i had this same problem....
i have a turbo timer hooked up and the wire for it was grounding out. take off the center consil and make sure all wires going the switch are ok.
Old Oct 4, 2005 | 02:54 PM
try new rear pads... if you're running stockish pads in Auto-X you're not doing it right to begin with (Auto-X is pretty hard on pads, believe it or not)
scooz14
Aug 21, 2007 03:18 PM
racesynergy
Apr 16, 2006 07:01 PM
jackyliem
May 17, 2005 07:21 PM
wishicoulddrift
Oct 1, 2004 01:52 PM
