hub bearing loose
Old Feb 15, 2006 | 05:40 PM
azndummie's Avatar
hub bearing loose
i just went in for an alignment a few weeks ago and they told me that they couldnt align the front becuase the hub bearing was worn out. im not sure if i need to replace the hub bearing or just tighten it because i dont think that the hub bearing is worn out, its a 97.
Old Feb 15, 2006 | 06:22 PM
silviasichigo's Avatar
Jack your car up on the tire they identified as having a bad wheel bearing and if you shake the tire and it wiggles back and forth then you ahve a bad wheel bearing and there is no tightening the wheel bearing only pressing in a new one.
Old Feb 15, 2006 | 08:08 PM
azndummie's Avatar
thanks a lot for the help everything u said was happening the wheel was wiggling and i need to get a new hub bearing pressed in thanks!
Old Feb 15, 2006 | 09:04 PM
Yep no problem, I have been through several (Drag racing) they tend to go more often than not.
wasaabi4784
Dec 6, 2005 08:10 AM
colombia
Nov 5, 2005 07:31 AM
BarnDog296
Aug 17, 2005 05:52 AM
darook
Jul 11, 2005 07:40 AM
ChuckGoon
Oct 25, 2004 01:27 PM
