I can't make up my mind, someone help
Old May 9, 2005 | 12:25 PM
JDMxDrift's Avatar
and good luck finding good priced wheels with 8" and 0 offset, they'll stick way too far out as well.
Old May 9, 2005 | 12:54 PM
Levi SPL S14's Avatar
if they stick out to far your to weak
Old May 9, 2005 | 12:55 PM
JDMxDrift's Avatar
Haha, i am too weak. I probably wouldn't be able to put the wheel on.
Old May 11, 2005 | 01:36 AM
naptime's Avatar
my pick goes to black racing even though I'm a fan of 5spokes
Old May 11, 2005 | 12:57 PM
DriftOrDieTryin's Avatar
i like the flat bronze look
its rare for me to like odd numberd spokes
but they look really good
witch side do you measer the offset from inside or outside ?
Old May 11, 2005 | 01:01 PM
JDMxDrift's Avatar
0 offset is center. If the hub mount go towards the outside of the wheel (The part you see when they are on the car) its positive, If the hub mount goes to the inside (towards the strut housing) its negative. So you measure from the center.
Old May 17, 2005 | 09:35 AM
Catharsis's Avatar
ummmmmmm ya a 8j with +25 will clear coilovers easy
Old May 18, 2005 | 11:26 AM
JDMxDrift's Avatar
they might clear but it will stick out almost another inch. Won't sit flush like i wanted them to
Old May 18, 2005 | 12:32 PM
phreze's Avatar
Roll your fenders or get wider ones. Just tell your boss you need some extra money case I said you need some wide fenders.
Old May 18, 2005 | 01:56 PM
Thats when you give camber a call and talk to her.
Old May 18, 2005 | 04:17 PM
  #26
JDMxDrift's Avatar
haha, "yeah bro, i'm running 45* of camber, i'm super JDM!!"
Old May 18, 2005 | 05:23 PM
  #27
Catharsis's Avatar
no it fits perfect check the offset thread... those are 9j's also
Old May 18, 2005 | 11:31 PM
  #28
JDMxDrift's Avatar
i read that thread and...
The 9j +35 is for the rear. The rear sinks in twice as much as the front. a 9j +48 or +50 will sit even with the fender in the front, BUT won't clear coilovers because they will sink in 48mm. I'm getting my info from a offset calculator from the Nico forums.
Catharsis, your statements are true, regarding the rear, but the front with a 8j+25 will extend ~40mm. I only need 20-25mm to sit flush.
Old May 19, 2005 | 03:22 AM
  #29
Catharsis's Avatar
ok be a puss....
they wont be very flush or very cool..
battosaii930
Aug 1, 2009 12:19 PM
ProjectMy240
Apr 12, 2005 05:56 PM
ixcocoyxi
Feb 16, 2004 06:35 PM
240SEX
Feb 25, 2003 02:05 PM
RNN14
May 16, 2002 04:49 AM
