LSD ignorance
Old May 30, 2004 | 10:56 AM
bradltl's Avatar
Post LSD ignorance
I have to admit my ignorance on this subject. I know what an LSD is, and why it's better than an open diff, but I don't know the differences between the "types" of LSD's.
What's the differences between a 1 way, 1.5 way, 2 way and any other types that I've not mentioned? I'm building my 240 for AutoX, so what are the pro's and con's for each? Which would you recommend?
Old May 30, 2004 | 11:35 AM
Re: LSD ignorance
ok if I miss something or get the details a little off, someone correct me:
VLSD - Viscous Limited Slip; uses fluid
Mechanical LSD - uses plates, a clutch or similar metal to metal contact
1-way - LSD only working when on throttle. pros: easy to learn driving with an lsd. cons: the second you let off the rpms the lsd might disengage, causing an inconsistency in handling.
1.5 way - LSD works on throttle, only slightly when braking. pros: full steering at off-throttle. cons: lsd action changes a little when you let off the gas.
2 way - LSD working at all times regardless of throttle. pros: consistent predictable lsd action at all times. cons: always squeaks when turning, can cause understeer during daily driving.
BTW this is from what I was told (I could be wrong)... try going to Kaaz site - they might have more detailed info for you
Old May 30, 2004 | 11:36 AM
Project Cheap13's Avatar
Almost everything you wanted to know about anything.......
http://auto.howstuffworks.com/differential.htm
s13silvia123
Feb 9, 2006 12:05 AM
focalguy
39
Mar 9, 2004 09:07 PM
Driftin180SX
May 6, 2003 01:31 PM
rudeboy
Sep 27, 2002 08:16 PM
Import Fanatix
Jun 8, 2002 11:20 AM
