Noise after subframe bushing install.
Okay, well I just did the splparts aluminum subframe bushing/ spacer install which totaly replaces the stock bushings. It is great, it stops the clunk noise and reduces wheel hop and everything. But right after I installed them and took her for a test drive I heard a new clunking/grinding noise. It sounds like it is coming from the diff but I'm not sure. It only happens when I go in reverse, take corners with the clutch in, coast at low rpm or pull into a parking spot. I'm stumped.
It wasnt there before I installed the spacers so I think it might be that the diff is at a different angle now that the spacers are in there??? If so what would fix that? Anything will help. I searched prior to posting but found nothing. Thanx
"Solid subframe bushings will transmit more drivetrain noise to the cabin"
from http://www.splparts.com/
There not saying the spacers are making the noise.
There telling you that what ever noise your rear end makes you will hear it alot louder than you did before.
BTW check your wheel bearings and brakes about that noise.
JDMxDrift
Jul 16, 2005 03:50 PM
HumanoidTyphoon
Jun 19, 2005 10:20 PM
