popping in front end. while breaking
Old Feb 27, 2004 | 11:22 AM
needasr20's Avatar
aight ppl my car for some reason has been popping really loudly in the front end.. only happens when i got in reverse and hit the breaks.. so today igot bored and i took my tension rods off and installed some aftermarket adjustable ones that i had sittin around.. went on just fine..even made my front end shimmey at 55 go away.. BUT the poping is still there.. maybe even harder .. i might be paranoid now .. but it's still poping and also does it when braking while goin forward now too but only sometimes.. i just want to know that i'm not gonna break sumthin and loose it at 65.. that would suck.. any help is appreciated..
Old Feb 27, 2004 | 12:00 PM
smokie700's Avatar
check your ball joints
Old Feb 27, 2004 | 02:14 PM
needasr20's Avatar
that would make the one big pop while breaking? or would it be more of a click click click
Old Feb 28, 2004 | 01:20 AM
smokie700's Avatar
well normally that sounds like a bad cvjoint but im still new to RWD and overall mechanics but i bet it would one of those two. ANY HELP from others? not sure if im giving the best advice
Old Feb 28, 2004 | 06:23 AM
needasr20's Avatar
ok i should have done better at describing it .. it's not a click click like cv joints.. it's one loud hard *** pop.. not everytime i brake only sometimes. but almost always happens in reverse.. i dont know ..it's wierd to me..but annoying.. thanks for tryin though man.. peace
Old Feb 29, 2004 | 01:06 PM
impact_grn_yosh's Avatar
i sorda have the same problem. i don't know what it is either but it makes a 'clunk' sound when i tap on the brakes. i'm starting to hear it from the right side rear now also. it's really wierd. my friend said it could be warped rotors, but i haven't quite gotten it checked yet. =T
Old Mar 3, 2004 | 02:03 PM
needasr20's Avatar
naw guys.. it's not in the back .. i can feel it and hear it from the front... it's not my brakes either. if it was my brakes it would happen everytime i hit the brakes in forward or reverse.. plus everytime i make it pop sumthing happens to my alignment.. if i do it in reverse it makes me pull hard to the left if it pops in forward my car will start to pull to the right.. it's aight though i'll just change all my links this week to my junkyard car.. my car was wrecked before and sumthin has to be bent that i cant see..
Old Mar 3, 2004 | 06:22 PM
Catharsis's Avatar
check to make sure all you bolts are torqued down
Old Mar 3, 2004 | 06:26 PM
needasr20's Avatar
werd
Old Mar 7, 2004 | 01:01 AM
240KAT's Avatar
Spring perch *****es. If you dont have coilovers or something with top camber plates, i'd check out the spiring perch (the top one)
Old Mar 7, 2004 | 06:37 AM
needasr20's Avatar
coilover sleeves .. sorry that aint it .. i think it might be my tie rods.. i just looked at them with the suspension all torn apart and they have the rubber boots cracked all up.. just ordered some new ones so we'll see what happenes
NiSmO Knight
Jan 25, 2008 11:56 PM
Alteus
May 9, 2007 12:55 PM
nolimitmr2
Mar 3, 2005 09:12 PM
duckman240sx
May 13, 2003 05:27 PM
Jonas
Oct 5, 2002 06:29 PM
