Rear Pad Help
Rear Pad Help
Doing a pad replacement on the rear brakes and I need some help. I took off the slide pin bolts and the caliper bolts and the pads and the spring retainers fell off. I am trying to figure out how to put in the new pads. I know which way the retainers go in but every time a I try to put everything together it all falls apart. Am I supposed to put back the caliper , install the pads and then the slide assembly? Maybe swing one end of the slide away from the caliper?
I like to keep the main caliper bolts in and tight, and loosen the top of the 2 "slide" bolts as us call them (the ones with the rubber boots protecting the sliding pins).
From there, you can just pop the new pads in place. There are tools available at PepBoys or other stores that you can insert to help rotate the piston back into place (some rears you have to do this to get the new pads to fit). I suggest getting this tool, and rotating the piston back in, then use a clamp to hold it temporarily till the pads are in.
Then take off the clamp and swing thatpart of the break back into place and retighten the bolt you took out.
Shouldn't take more than 15-20 minutes per wheel.
Thanks Guys!
I installed the pads today after mounting the caliper 1st then installing the pads. I had to kind of angle the pad so that the bottom of the tabs slide in 1st then pop in the top using a flat blade to pry the retainer open. The torque member and slide pins went in last as instructed.
Great forum!
Great forum!
It's really easy to do brake pads without taking the whole caliper off.
Like I said, if you just undo the top bolt that screws into the sliding pin (with the rubber boot on it to hold the grease in), you can swing the back part of the brake down and get to the pads with the caliper still on.
Glad you got em on though
