SR rebuilding
Old Jan 23, 2005 | 03:33 PM
CKAMC's Avatar
SR rebuilding
Well I am currentlu in the process of rebuilding an Sr *dont have the clip but have many parts tho* and had some questions. I dont have much cash to spare out so I was wondering if is some new stock pistons would 18 or less psi. is there any place that sells stock SR rods?
Also I have on order a Silk road outlet pipe and was wondering what o2 sensor would fit in it *either the redtops o2 or the blacktops*
thanks for the info people
~chris
Old Jan 23, 2005 | 06:54 PM
chiroke's Avatar
have the stock rods treated i forgot what its called but it makes em stronger
Old Jan 26, 2005 | 08:31 PM
goneturbo's Avatar
18psi and a limited amount of funds is not a good idea. Save your money until you can build the bottom end correctly. Either that or limit your boost to 12-14 psi with the stock bottom end... you can buy stock rods, getting some used ones would be a better cost option. Aftermarket new rods would be cheaper than stock ones new...
Old Jan 28, 2005 | 08:39 PM
drnovascotia's Avatar
ask silk roads about their outlet pipe . . my o2 sensor is off a 87 300zx. . for a s13 redtop
like they said don't halfass a SR build, you'll regret it. Check the SR FSM for the parts ##s and go from there.
Dr.
Old Feb 1, 2005 | 06:50 PM
donteventry's Avatar
Ive seen the SR rods and pistons in super street mags...the place has their own website too i just cant remember...ill post when i find the site
Old Feb 3, 2005 | 06:44 PM
bottombunk's Avatar
is the sr blown? if not dont rebuild it. rebuilt engines hardly ever drive like oem ones. especially if your on a limited budget. if it is blown have them shot-peened, the rods that is. as for pistons check out race engineering (www.raceeng.com). good luck.
guy
Sep 21, 2004 03:28 PM
l2aine
Jun 14, 2004 10:58 PM
twofortyessex
Feb 12, 2004 01:12 PM
Jonas
Jun 4, 2003 10:08 AM
adavib
Apr 20, 2003 10:29 PM
