Turbo chargers from old cars and trucks?
Old Oct 21, 2003 | 06:41 AM
NOS_is_4_cheat's Avatar
I have always wanted to know if there is any way you can get a turbo off of an old deisel truck or car and use it on a 240sx...i thought there might be some kind of way to make it work...do you guys have any clues?
Old Oct 21, 2003 | 08:44 PM
mandoz85's Avatar
Any turbo will fit. the problen is finding a manifold that will fit the turbo. if you get a custom manifold to fit the turbo that you have have then there is no problem.
Old Oct 22, 2003 | 06:09 AM
sweet...can you use the same manifold the the turbo came off of?
Old Oct 22, 2003 | 01:19 PM
mandoz85's Avatar
No you wont be able to use the manifold that the turbo comes with. the manifold has to be made so it will fit your engine. you have to find someone to make you a manifold that will bolt on to the KA and to the turbo that you want to use. The best choices would be to use a big t3 or a T3/T4 that way it is easier to find a manifold. there are companies that make mnifolds for these turbos such as realnissan.
http://www.realnissan.com/parts.asp
Old Oct 24, 2003 | 07:37 AM
is it expensive to get a custom manifold??
Old Oct 24, 2003 | 02:08 PM
mandoz85's Avatar
It depends on where you get it made. Also it will depend on what the manifold is made of. Most of the time it should be less the any premade maniflod that you can buy.
Old Oct 26, 2003 | 09:13 AM
Monkey Force's Avatar
You can also try a cheaper method that produces varied results...
You can make an adapter flange that will mount the turbo on the existing flange of the manifold.
Old Oct 27, 2003 | 07:05 AM
oOoh
Project Cheap13
Mar 24, 2008 09:08 PM
energy0uth
Feb 4, 2008 11:49 PM
E Spin
Jan 1, 2007 10:48 AM
jackyliem
Dec 14, 2004 10:51 PM
bztech
Jan 19, 2004 09:51 PM
