tire fitment on an s14
Old Jun 11, 2007 | 02:26 PM
well ive decided to go with the Work Emotion CR-Kai 17x9 +17 all around on my s14 and i want Falkan Azeni RT-615 tires 255/40 ZR17.
my question is how bad will a 255 tire rub in the front i know 255 will be fine in the rear but not sure about the front.
i was hoping with +17 offset it will only rub on the fender and all i need to do is roll the fender a bit im just hoping it dosnt rub the wheel well
Old Jun 12, 2007 | 02:01 PM
bucket240's Avatar
you should get 235's all around for the stretch and it wont rub at all.
Old Jun 12, 2007 | 02:14 PM
CharlesJ's Avatar
Club240 Staff
yeah, a stagger in tire size would be the easiest solution. You need to pull on your front fenders quite a bit to get that to clear to the point of being a front widebody. I would run a 235 as there is really not much reason for a 255 up front.
Old Jun 12, 2007 | 03:07 PM
255 is freaking huge. anywhere from 215 to 245 will fit nicely because of manufacturers measurement difference.
edit, whoops didnt see you already had a tire in mind, i dont have experience with azenis so disregard this post.
Old Jun 12, 2007 | 03:15 PM
hmm i dont want a stretched tire hmm ill find someone with a 255 to see how much id have to roll it if not i guess ill got 245 fron 265 rear but i did want it to keep it the same size
SmokedZenki
Jun 27, 2008 07:50 AM
StarScream_s13
Jan 21, 2006 03:32 PM
s14joe
May 18, 2004 09:42 PM
S14cj
Feb 22, 2004 12:10 PM
LigouriRd
16
Nov 25, 2003 11:23 AM
