for those that have installed subs in the trunk
Old Dec 28, 2004 | 10:29 PM
illipse's Avatar
im trying to figure out all my possibilities for how to go about this with the trunk layout. i have a 95 240sx and there is a big hole in the middle where the spare goes. so if anyone has installed a sub with the same trunk layout, can you throw me some knowledge of what you did.
i got some ideas, but just wanna see what has worked for people.
thanks
Old Dec 28, 2004 | 10:39 PM
LTSCUDRFT's Avatar
put the sub in your room.... lol... it adds weight..
Old Dec 28, 2004 | 10:55 PM
sr20det power's Avatar
i wouldnt take out the spare, u might need it, i wouldnt sacrifice that for a sub if anything mount a 10 inch or 2 between the backseat and the trunk area where u cant really see
Old Dec 29, 2004 | 08:55 AM
2fast4y0u's Avatar
i made triagnle boxes and put them in the corners passanger and driver. its sweet looking. all you see when u look in my trunk are 2 sub magnets. its nice ill take a pic and post it later
Old Dec 29, 2004 | 04:34 PM
illipse's Avatar
yea lemme get some pics of those. i already have a 12" in a box so i dont think ima try to build anything new. at least for now,but just trying to figure out where to place this one at.
Old Dec 29, 2004 | 05:44 PM
2fast4y0u's Avatar
yeah not a prob. im supposed top go see my car tomorrow. so if i do ill post some pics for ya
Old Jan 11, 2005 | 10:03 AM
hotimportknight's Avatar
I have a giant leet pwnage JL Audio 13W7 huge stealth black sexy looking sub, with like a 2" wide surround that covers up all the mounting with its unique mounting layout. I am trying to find out if i can make a custom fiberglass enclosure with the mail volume of the enclosure being in the spare tire compartment. Ill list the specs, if i cut out the middle thingy will it be deep enough to sit almost never level with the rest of the trunk? i dont have my 240 yet so i cant see for my self, but i think mounting depth is around 10" ill copy/paste the specs.
Dimensions:
Frame Diameter: 14 in. (356 mm)
Mounting Hole Diameter: 11.9 in. (302 mm)
Mounting Depth: 10.5 in. (267 mm)
Overall Depth: 12 in. (305 mm)
Magnet Diameter: 8.38 in. (213 mm)
Pole Vent Clearance: 0.75 in. (19 mm)
Displacement: 0.21 cu. ft. (4.5 ltrs)
Enclosure Recommendations:
Sealed Range: 1.5 - 2.25 cu. ft. (42.48 - 63.72 ltrs)
Recommended Sealed Volume: 1.875 cu. ft. (53.1 ltrs)
Fc: 40.8 Hz
F3: 36.3 Hz
Qtc: 0.806
Ported Range: 2.0 - 2.75 cu. ft. (56.6 - 77.9 ltrs.)
Recommended Ported Volume: 2.375 cu. ft. (67.3 ltrs)
Recommended Tuning: 30 Hz
I would of course make it a sealed enclosure, but this would look SOO BADASS having this sexy JL 13w7 sitting in the middle of the trunk with its HUGE surround and a nice big JL 1000.1 sitting behind it, or floating on an amp rack, please give me some feedback on the depth of the spare tire well, i could cut out the center mounting point and free up some more room. thanks.
Old Jan 11, 2005 | 01:23 PM
djradam's Avatar
there's not a lot of room at all. i have 2 12s, with my amps, my trunk is filled. i made a custom L shaped box
Old Jan 15, 2005 | 02:58 PM
2fast4y0u's Avatar
I finally have a pic of my install for you. sorry it took so long. but here it is.
Old Feb 12, 2005 | 04:12 AM
wikd240's Avatar
hotimportknight
that jl 13w7 is a serious sub... building a fiberglass enclosure for it would be a big task... fiberglass will flex if it is not thick enough and with the pressure from a 13w7 with a jl 1000/1 amp pushing it there would be a lot of reinforcement needed to keep that box together... the ho wedge box that the sub is in is one hell of a box... huge as hell... even in the spare tire well there would have to be a lot of reinforcement on the metal and box to keep it from flexing... it can be done if you really want... you can find me on aim most of the time or pm me here and i will help you with the construction as well as send you a few pics of some other systems i have done with fiberglass...aim screen name wikd24d
battosaii930
Jan 16, 2007 09:12 PM
KeN VeRsUs RyU
Sep 11, 2006 01:25 AM
prjkt240
27
Jan 18, 2006 03:50 PM
colombia
Dec 21, 2005 08:39 AM
SOUND2NR
Aug 29, 2002 04:08 PM
